Bongo Ariel
Bongo Ariel
Somewhere unknown my ariel has snapped off at the base. Does anybody know where I can get a replacement. Could not find any in the Bongo shop!
Re: Bongo Ariel
I thought you were going to put your Bongo in the washing machine. 60 degree spin cycle?
Bongo Shop --> Exterior --> Aerial (last item, £32.50 with member discount)
P***AHO - "Hoptoad" - 1997 2.5TD
2WD - AFT - DIY mid conversion
Re: Bongo Ariel
The aerials are at the bottom of the Exterior section http://www.igmaynard.co.uk/bongo/mercha ... m#Exterior
- haydn callow
Re: Bongo Ariel
when you come to replace your aerial.....mind you don't lose the VERRY SMALL ball bearing.....if you drop it ...it;s gone for good
Re: Bongo Ariel
Thanks for the above, chaps. I was agonizing over wether it was an 'e' or an 'a'.
Re: Bongo Ariel
Depends; 'e" for washing clothes, or 'a' for listening to the wireless
Re: Bongo Ariel
Don't forget the extra "e"(after the first "a") to pick up radio signalsg8dhe wrote:Depends; 'e" for washing clothes, or 'a' for listening to the wireless
Re: Bongo Ariel
If you fancy something a bit different, there was a thread on the pimp my bongo forum about this:
http://www.igmaynard.co.uk/bongo/forum/ ... lit=aerial
Basically, my aerial (think that's how you spell it!) got chewed up by my AFT. At the advice of Barrington and Scott (thanks guys!) I cut off the remainder of the aerial at the base of the chrome bit (where it joins the black plastic). I then drilled (using an m5 bit) into the "core" of the metal. This was dead easy because the aerial is hollow, so it's like a pilot hole has already been made for you. I then got an M6 tap and cut a thread into the hole, again dead easy, even though I'd never used one before. This then allowed me to screw in a Halfords £10 whippy aerial that should be impervious to future eating attempts by the electric roof
Also, it's straightforward to remove should I ever risk going through a car wash
Personally I think the new aerial looks neater than the old one and I'd say it's probably as easy a job as fitting a replacement official part since there's no ball bearing to lose.
Re: Bongo Ariel
As Gigantor says dead easy and looks smarter too
also easy screw off
Music is my Sanctuary!
Re: Bongo Ariel
If I do the drill-tap-and screw the aerial with a Halfords job, do I need to remove the aerial from the side of the van or leave it in place to drill etc? I assume there is a wire connecting the aerial at the base.
Re: Bongo Ariel
I drilled mine in-situ, the connection is via the rotating hub there are no wires inside the rotating section. Saves loosing the sprung ball bearing which gives the locking detents
Re: Bongo Ariel
That's neat baz... And STILL on my "to do" list!Barrington wrote:As Gigantor says dead easy and looks smarter tooalso easy screw off
Re: Bongo Ariel
Thank you buddy
bigdaddycain wrote:That's neat baz... And STILL on my "to do" list!Barrington wrote:As Gigantor says dead easy and looks smarter tooalso easy screw off
Re: Bongo Ariel
Excellent, will give this a go at some point as I discovered my ariel had been broken by the garage but I'd not really noticed before driving off and changing from CD to fm and wondering why it didn't work.........
.......for the tools etc. it'll be cheaper than a new one at £32+ or something
- westonwarrior
Re: Bongo Ariel
Heres how if you take the stub off the van first
http://www.igmaynard.co.uk/bongo/forum/ ... =bee+sting
