fuel cap fix?
skater
fuel cap fix?
Post by skater » Fri Nov 19, 2010 1:40 pm
Quick question. Is the fuel cap "serviceable"?
Mine does the "air sucking" thing when opened after a longer journey,
especially if brimmed before journey.
Have searched but didn't find my answer.
Thanks, James.
" it's not rocket surgery! "
2sticks
Re: fuel cap fix?
Post by 2sticks » Fri Nov 19, 2010 4:48 pm
That's how it should be. There is a vacuum relief valve in case the
pressure (vacuum) gets too low in the tank which will stop the tank
collapsing. It's designed to stop fuel fumes escaping from the tank.
skater
Re: fuel cap fix?
Post by skater » Fri Nov 19, 2010 6:04 pm
So there shouldn't be an " intake breath " when cap opened?
Should the vacuum relief valve keep pressure equalised as the fuel is used?
teenmal
Re: fuel cap fix?
Post by teenmal » Fri Nov 19, 2010 7:01 pm
skater wrote:So there shouldn't be an " intake breath " when cap opened?
Hi skater,
That how it works, :)
Cheers..
skater
Re: fuel cap fix?
Post by skater » Fri Nov 19, 2010 7:11 pm
That's what I thought.
So my cap doesn't seem to be relieving the pressure drop.
Has anyone fixed theirs or do I just buy a new one?
Thanks.
Re: fuel cap fix?
Post by francophile1947 » Fri Nov 19, 2010 7:53 pm
I think they may be designed to keep a slight vacuum, because mine always did make a slight hiss when removed.
However, mine did bung up (probably with veg oil), so I just put it in hot, soapy water for a few minutes, until I could easily suck air through it - no problems since 8) :lol:
skater
Re: fuel cap fix?
Post by skater » Fri Nov 19, 2010 8:54 pm
ah, good idea. probably won't try sucking through it though. :D
mister munkey
Re: fuel cap fix?
Post by mister munkey » Fri Nov 19, 2010 9:29 pm
If you need one, I have a spare cap Skater, PM me an address & I'll bung it in the post.
Re: fuel cap fix?
Post by francophile1947 » Fri Nov 19, 2010 9:45 pm
skater wrote:ah, good idea. probably won't try sucking through it though. :D
Oh go on :lol: :lol: I did rinse the soap off first, so I was just sucking clean plastic and you know that air will go through it again 8) :lol:
brorabongo
Re: fuel cap fix?
Post by brorabongo » Thu Nov 25, 2010 12:43 am
I stripped my cap at the beginning of July, and never bothered putting back together since. I don't run with a full tank, as it might leak through the cap? I've not noticed any difference in the running of the Bongo.
http://www.igmaynard.co.uk/bongo/forum/ ... ap#p427070
ボンゴの激怒 pictures
skater
Re: fuel cap fix?
Post by skater » Thu Nov 25, 2010 10:30 am
Thanks mister munkey, have washed mine as recommended :shock:
Haven't done long journey yet but think the intake breath seems a bit less when checked so far.
James.
haydn callow
Re: fuel cap fix?
Post by haydn callow » Thu Nov 25, 2010 11:03 am
Intake breath is normal !!
http://www.coolantalarm.co.uk
Also BMW Clocks
Barrington
Re: fuel cap fix?
Post by Barrington » Thu Nov 25, 2010 11:36 am
Ive always had slight intake of breath from the fuel tank mostly on empty, is this normal then????
Music is my Sanctuary!
haydn callow
Re: fuel cap fix?
Post by haydn callow » Thu Nov 25, 2010 11:44 am
yes
Also BMW Clocks
Barrington
Re: fuel cap fix?
Post by Barrington » Thu Nov 25, 2010 11:46 am
Cheers Haydn :D
