fuel cap fix?
fuel cap fix?
Quick question. Is the fuel cap "serviceable"?
Mine does the "air sucking" thing when opened after a longer journey,
especially if brimmed before journey.
Have searched but didn't find my answer.
Thanks, James.
Thanks, James.
" it's not rocket surgery! "
Re: fuel cap fix?
That's how it should be. There is a vacuum relief valve in case the
pressure (vacuum) gets too low in the tank which will stop the tank
collapsing. It's designed to stop fuel fumes escaping from the tank.
Re: fuel cap fix?
So there shouldn't be an " intake breath " when cap opened?
Should the vacuum relief valve keep pressure equalised as the fuel is used?
Re: fuel cap fix?
skater wrote:So there shouldn't be an " intake breath " when cap opened?
Hi skater,
That how it works,
Cheers..
Re: fuel cap fix?
That's what I thought.
So my cap doesn't seem to be relieving the pressure drop.
Has anyone fixed theirs or do I just buy a new one?
Thanks.
Thanks.
Re: fuel cap fix?
I think they may be designed to keep a slight vacuum, because mine always did make a slight hiss when removed.
However, mine did bung up (probably with veg oil), so I just put it in hot, soapy water for a few minutes, until I could easily suck air through it - no problems since
Re: fuel cap fix?
ah, good idea. probably won't try sucking through it though.
- mister munkey
Re: fuel cap fix?
If you need one, I have a spare cap Skater, PM me an address & I'll bung it in the post.
Re: fuel cap fix?
Oh go onskater wrote:ah, good idea. probably won't try sucking through it though.
- brorabongo
Re: fuel cap fix?
I stripped my cap at the beginning of July, and never bothered putting back together since. I don't run with a full tank, as it might leak through the cap? I've not noticed any difference in the running of the Bongo.
http://www.igmaynard.co.uk/bongo/forum/ ... ap#p427070
Re: fuel cap fix?
Thanks mister munkey, have washed mine as recommended
Haven't done long journey yet but think the intake breath seems a bit less when checked so far.
James.
James.
- haydn callow
Re: fuel cap fix?
Intake breath is normal !!
Re: fuel cap fix?
Ive always had slight intake of breath from the fuel tank mostly on empty, is this normal then????
Music is my Sanctuary!
- haydn callow
