Roof maintenance
PaulH
Roof maintenance
Post by PaulH » Wed Aug 25, 2010 4:38 pm
My roof is working fine and goes up and down without problem but it occurs to me that it might be good to do a bit of preventative maintenance - like lubricating the moving parts. Does anyone have any experience of this - like what to lubricate, and what the best oils/greases are. I could just go down the WD40 route, but suspect some of the parts may benefit from something more sophisticated.
I live in horror of getting stuck somewhere with the roof jammed up.
PaulH
Bin Bongoed
Re: Roof maintenance
Post by Bin Bongoed » Wed Aug 25, 2010 4:44 pm
Somebody recommended silicone spray for the struts, which has worked fine on mine (it was juddering when operated).
the smoker
Post by the smoker » Wed Aug 25, 2010 5:22 pm
furniture polish is silicon based. and smells good to. just us light oil that will stop the judder.
haydn callow
Post by haydn callow » Wed Aug 25, 2010 5:23 pm
Clean off all the old muck with white spirit......then use white lithium spray grease (Halfords) this is less likely to stail the canvas if you get any on.
http://www.coolantalarm.co.uk
Also BMW Clocks
dobby
Post by dobby » Wed Aug 25, 2010 11:01 pm
Has anyone successfully removed the black marks that the lifting mechanism causes on the AFT tent fabric?
wormey
Post by wormey » Thu Aug 26, 2010 12:54 pm
dobby wrote:Has anyone successfully removed the black marks that the lifting mechanism causes on the AFT tent fabric?
I found wet wipes removed alot of the mess from the material. :D
Daz and debs
Andyf
Post by Andyf » Thu Aug 26, 2010 1:00 pm
Baby wipes did it for me! I don't know what we did before we had a kid, we use these things for everything!! :o
www.bongodecals.com
Manufacturer of quality replacement decals for Mazda Bongo's and Ford Freda's
the smoker
Post by the smoker » Thu Aug 26, 2010 5:51 pm
sounds daft but Wd 40 does a good job so does pledge polish..
dobby
Post by dobby » Thu Aug 26, 2010 9:29 pm
Thanks all, I'll give it a try this weekend
LoopyLoo
Post by LoopyLoo » Fri Aug 27, 2010 8:21 am
I need to do ours too, it goes up ok but is a bit creaky coming down.
Do I just raise the roof up and wipe over the struts with a cloth with polish/spray stuff on it?
Feel a bit daft asking tbh!
mister munkey
Post by mister munkey » Sun Aug 29, 2010 4:01 pm
I think this came up last year, someone said WD40 isn't such a good idea as it tends to damage the seals on the rams after a while . . . . . :-k
I use this stuff on the rams & runners.
Works a treat!
Barrington
Post by Barrington » Sun Aug 29, 2010 5:21 pm
Used this stuff as advised by MR M works a treat never looked back :D
mister munkey wrote:I think this came up last year, someone said WD40 isn't such a good idea as it tends to damage the seals on the rams after a while . . . . . :-k
Works a treat!
Music is my Sanctuary!
