Coolant Change
- missfixit70
Re: Coolant Change
Certainly won't hurt, may shave a bit of time & cut down on thermal stresses maybe?
Re: Coolant Change
Thats a dead ringer for the workshop manual diagram. Can that be seen and/or accessed/removed without removing the engine under cover, do you know Mike?mikexgough wrote:
- mikexgough
Re: Coolant Change
I must admit to taking a look see..... sometime ago....as you can see Mike the scavenger fan can be seen in the picture so in essence it is covered by the under tray... which is probably why this drain "noozle" as called by a certain BigDaddyCain, is never mentioned in most of the coolant change threads and bleed methods....
- The Great Pretender
Re: Coolant Change
And also turn the Bongo upside down to evacuate any trapped air before refitting the pipe plug.missfixit70 wrote:definitely not a good idea to intentionally leave old stuff in there IMO, get it flushedit doesn't take long
To infinity and beyond
Re: Coolant Change
mikexgough wrote:which is probably why this drain "noozle" as called by a certain BigDaddyCain, is never mentioned in most of the coolant change threads and bleed methods....
Re: Coolant Change
Thanks for all your posts and esp the pic. Have put it off this weekend due to the poor weather but tomorrow looking hopefull. Now loaded with more antifreeze and an extended garden hose.
Cheers again . Reebs
