Coolant Change
Re: Coolant Change
Post by missfixit70 » Fri Apr 02, 2010 5:16 pm
Certainly won't hurt, may shave a bit of time & cut down on thermal stresses maybe?
Re: Coolant Change
Post by mikeonb4c » Fri Apr 02, 2010 8:51 pm
mikexgough wrote:Image
:wink: :wink:
Thats a dead ringer for the workshop manual diagram. Can that be seen and/or accessed/removed without removing the engine under cover, do you know Mike?
mikexgough
Re: Coolant Change
Post by mikexgough » Fri Apr 02, 2010 8:58 pm
I must admit to taking a look see..... sometime ago....as you can see Mike the scavenger fan can be seen in the picture so in essence it is covered by the under tray... which is probably why this drain "noozle" as called by a certain BigDaddyCain, is never mentioned in most of the coolant change threads and bleed methods....
The Great Pretender
Re: Coolant Change
Post by The Great Pretender » Fri Apr 02, 2010 11:05 pm
missfixit70 wrote:definitely not a good idea to intentionally leave old stuff in there IMO, get it flushed [-X it doesn't take long :wink:
And also turn the Bongo upside down to evacuate any trapped air before refitting the pipe plug. :wink:
To infinity and beyond
Re: Coolant Change
Post by mikeonb4c » Sat Apr 03, 2010 10:51 am
mikexgough wrote:which is probably why this drain "noozle" as called by a certain BigDaddyCain, is never mentioned in most of the coolant change threads and bleed methods....
:lol: :lol: :lol: I wonder if others may now 'come out' and admit they didn't remove their noozle before draining their coolant. :oops: :shock: :roll: 8)
Reebs
Re: Coolant Change
Post by Reebs » Sun Apr 04, 2010 8:24 pm
Thanks for all your posts and esp the pic. Have put it off this weekend due to the poor weather but tomorrow looking hopefull. Now loaded with more antifreeze and an extended garden hose. :) Cheers again . Reebs
