Hi there - about to take our petrol/LPG V6 Bongo to have a service and MOT. Its the first time we've sent it for MOT/service - can someone please advise what must be done on the Bongo to keep it clear of any problems - can't remember how often a petrol needs an oil change for example.
Just want to make sure the garage goes through it all (its a recommended garage on the members board - Romford Mazda - but just in case they miss something?)
Any tips appreciated!
									MOT/service query - V6
Check out our tunes!
http://www.myspace.com/scowlinowl
Re: MOT/service query - V6
Hi there,
Depends on what has been done to date and when really.
As a minimum you should be looking at:
New Oil and filter
New air filter
Check auto gearbox and rear diff oil
Check drive belts
Check brakes and suspension etc
On a yearly basis I also:
Change the spark plugs
Change wiper blades
2 Yearly:
Change coolant
Change brake fluid
Change auto box oil
Change rear diff oil
The LPG system should be checked/serviced around every 20k or 2 years depending on system.
I've probably missed something but it's a starting point.
Good luck.
Andy
Some of that maybe OTT but I figure it's best to look after the car properly
Offical things that I can remember are:
Engine oil and filter every 15k km.
Cambelt every 100K km.
New Oil and filter
New air filter
Check drive belts
Change wiper blades
2 Yearly:
Change coolant
Change brake fluid
Change auto box oil
Good luck.
Andy
