hello read lots of the posts re this - boy it gets confusing
basically mine fuel guage just now is showing totally empty - if i remove the wire connection and pop it back on then fuel guage will go to what it should be and it will then slowly drop while driving. am i correct in saying this is the earth issue and i just need to disconnect the batteries ,cut the earth wire and pop a tail on it and earth it to one of the screw point's (wire wool the point so that i get better connection)
the old dodgey fuel guage
Re: the old dodgey fuel guage
If you mean under the plate between the rear seats then yes, I made a second earth as a failsafe as well.
- missfixit70
Here you go - description with pics - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=33920 - factsheet in the members area too.
what guage of wire should be used for this
I think I just a piece of some speaker wire or similar I had handy for mine, still working after a couple of years anyway,lol.
