Intermittent wipers
Bigcol
Intermittent wipers
Post by Bigcol » Mon Feb 15, 2010 7:27 pm
Hi dudes. The intermittent jobbie on the wipers of my Bongo does not work (never has in the few months we have owned it). The wipers run full time if I move the stalk to intermittent. Being the lazy sod that I am, I'm getting tired of keep moving the stalk up and down in our drizzle soaked nation. Any ideas gratefully received. Thanks.
Alison01326
Re: Intermittent wipers
Post by Alison01326 » Mon Feb 15, 2010 7:34 pm
May sound daft, but does yours have the little adjustment ring thingy on it (there must be a proper name). One way the intermittent is very intermittent, and the other way it's almost "normal". Don't know if all the Bongos have them, but it might be worth twiddling it if yours does.
Just a thought!
Alison
mister munkey
Post by mister munkey » Mon Feb 15, 2010 7:35 pm
Obvious first.
Have you twisted the adjuster on the stalk all the way round. At one end of the scale its pretty much constant. the other way its every 5 or 6 seconds . . . .
Edit: Pipped by the South West Sharpshooter again! :lol:
Alison01326
Post by Alison01326 » Mon Feb 15, 2010 7:58 pm
Ah, but in my haste to get in there first, I used the word "thingy" which is NOT a technical term :oops:
Alison
Bigcol
Post by Bigcol » Mon Feb 15, 2010 9:22 pm
Sadly the twisty thingy adjustambob does not make a jot of difference.
Post by g8dhe » Mon Feb 15, 2010 9:33 pm
If the Low & High speeds and One Shot work and the wipers return to the Home position OK, then there isn't anything amiss with the wiring which means that it can only involve the actual Stalk and the timer module which appears to be built in to the stalk itself.
mister munkey
Post by mister munkey » Mon Feb 15, 2010 10:06 pm
Geoff is rarely wrong.
Suggest new stalk. Luckily both Ebygum32 & Tonic are both breaking Bongos at the moment - suggest a subtle Pm . . . .
8)
stilldesperate
Post by stilldesperate » Mon Feb 15, 2010 10:26 pm
I'm breaking a mazda MX6, I think they're the same ......
(Only joshing, Mr Monkey :lol: )
SD
"The older I get, the faster I was"
Post by g8dhe » Mon Feb 15, 2010 11:04 pm
mister munkey wrote:Geoff is rarely wrong.
I wish :lol:
mister munkey
Post by mister munkey » Mon Feb 15, 2010 11:10 pm
stilldesperate wrote:I'm breaking a mazda MX6, I think they're the same ......
SD
Y'know, its easy to go off some folk.
