TYRES AND BLOWOUTS
- Muzorewa
Re: TYRES AND BLOWOUTS
I suppose we could add the "spare" worm where people replace the skinny with a full-size spare - but if you're running regulation sized tyres front & rear your spare clearly only suits one axle, so say you get a puncture on the other axle, fit the spare which isn't the right size, and then have a major incident on your way home......
- thepickles
Kirsty,
You've done it now
I will expect a definitive answer by the end of the evening
Steve
You've done it now
Steve
- missfixit70
Twas you that asked the question
Nope, must be 60 years since I ate worms and they were fresh, not out of a rotten old canmissfixit70 wrote:Can somebody give me a hand to get all these worms back in & the lid back on before anyone notices![]()
- thepickles
Exactlymissfixit70 wrote:Twas you that asked the question![]()
Can I have the answer please
cheers
Steve
- missfixit70
As thread hijacks go, that's a pretty good one
richlizard
Think I will post all my infor when it is all calmed down!
- missfixit70
richlizard wrote:Think I will post all my infor when it is all calmed down!
What a coincidence, I was going to ask what size spare to get. I recently joined the ranks of Bongo owner and was checking the spare wheel out today, just to see what sort was there. It turned out to be a skinny spare and after reading the recomendations on dumping these and replacing with a full size spare I thought I would do that......but what size? The Bongo is 1995 2WD with full side conversion and 195 front tyres with 215 rears, so what size spare do I get? My thought was a 195 as I would have thought it best to keep the same size tyres on the front so as not to get any steering problems but different sizes on the rear wouldn't create many problems as a get home solution. Is my thinking correct, ignoring any insurance doubts for the moment as you would have the same problem using the factory supplied skinny......or would you?Muzorewa wrote:I suppose we could add the "spare" worm where people replace the skinny with a full-size spare - but if you're running regulation sized tyres front & rear your spare clearly only suits one axle, so say you get a puncture on the other axle, fit the spare which isn't the right size, and then have a major incident on your way home......
Never run out of road, traction and ideas at the same time.
- mister munkey
rapiddescent wrote:I don't seem like a total nerd, but the post a few above mistakes "weight" and "mass". The arithmetic above assumes the vehicle is stationary. - of course, they aren't, the bongo's are bongo'ing along into and out of dips and the tyres take pressure round corners.
example 1:
entering a dip - like the ones on the A93 near spittal of glenshee. the bongo will "weigh" 1.3 times its mass as it hits the bottom of the dip. the tyres not only are taking mass x gravity (but are also got the upwards acceleration of hitting he upswing in the road). If you manage to get the bongo off the ground, or are travelling faster, then the forces increase dramatically! For the non-rally drivers: hitting a square edged sleeping policeman, or kerb, at 30mph may also exert a similar force on the tyre,
example 2:
moose avoidance manoeuvre; basically, two outside cornering tyres will be taking 75% of the weight loading of the vehicle.
Positively enlightening!!
Its all starting to make sense now!!
Anyway, back on track . . . .
Likely caused by knackered tyres, a lesson learned & another space saver sent to Room 101.
- missfixit70
I'd agree with your thinking, making sure the load & speed rating is up to par - whatever par isTessie wrote:What a coincidence, I was going to ask what size spare to get. I recently joined the ranks of Bongo owner and was checking the spare wheel out today, just to see what sort was there. It turned out to be a skinny spare and after reading the recomendations on dumping these and replacing with a full size spare I thought I would do that......but what size? The Bongo is 1995 2WD with full side conversion and 195 front tyres with 215 rears, so what size spare do I get? My thought was a 195 as I would have thought it best to keep the same size tyres on the front so as not to get any steering problems but different sizes on the rear wouldn't create many problems as a get home solution. Is my thinking correct, ignoring any insurance doubts for the moment as you would have the same problem using the factory supplied skinny......or would you?Muzorewa wrote:I suppose we could add the "spare" worm where people replace the skinny with a full-size spare - but if you're running regulation sized tyres front & rear your spare clearly only suits one axle, so say you get a puncture on the other axle, fit the spare which isn't the right size, and then have a major incident on your way home......
- rapiddescent
I'm going for the 215 for my spare! for 2 reasons:
1: I'd much rather have a spare over-rated tyre than an under-rated tyre.
2: you are much, much more likely to get a rear puncture because nails etc are flipped up by the front tyres.
however,
+ if you live in somewhere like milton keynes. get a front, because you are going to wear out the front left tyre very quickly, so at least you have another tyre to even out the wear!
however,
Ford Freda owning mountain biker dude
- missfixit70
215 is not the rating, it's the width, so a 195 is not "underrated", it depends on what rating 195 you getrapiddescent wrote:I'm going for the 215 for my spare! for 2 reasons:
however,
- rapiddescent
is this the pedantry corner! clearly the "tyre rating" (usually a single letter depicting max speed rating) and the "width" (in mm) are different and not to be confused.
I think most would prefer width over speed anyway.
rapiddescent wrote:is this the pedantry corner! clearly the "tyre rating" (usually a single letter depicting max speed rating) and the "width" (in mm) are different and not to be confused.
