REMOTE LOCKING
Re: REMOTE LOCKING
prior owner of >>>>1999 2.5 diesel ex tin top &FORD FREDA 2000 2.0 LTR PETROL
Re: REMOTE LOCKING
Colin, where did you get the kit from ?
The user formerly known as csmcqueen
スコット
スコット
Re: REMOTE LOCKING
Hi CQ, I went for this one free P&P as I already had an actuator that a member sent me as he had a spare one,,, Colin
http://cgi.ebay.co.uk/Car-Keyless-Remot ... 255867ed1b
Re: REMOTE LOCKING
Main control box looks identical to mine, a stroll in the park to wire up mateyColin H F wrote:Hi CQ, I went for this one free P&P as I already had an actuator that a member sent me as he had a spare one,,, Colin
スコット
スコット
Re: REMOTE LOCKING
Colin
Dunno if this is of any help to you, I was too lazy to go the whole hog and wire up indicators etc and mounted mine in the door, 2 connections to Bongo and 2 to the actuator, then stuck it to inside of door panel. But if your control unit is the same then there is a good chance your loom coming off it is the same too
Scott
Scott
スコット
スコット
Stinch
Re: REMOTE LOCKING
I've ordered a kit from Right click.
Going to fit it on sunday
Thanks for the info
Thanks for the info
Re: REMOTE LOCKING
heres my wiring diagram connected the 12volt possatives, and the negatives, to facilitate the change over relays which operate the actuator
Re: REMOTE LOCKING
Neal, a separate trunk release will require an actuator & wiring through & into the tailgate..? Maybe using somthing like this..? http://www.in-car-stuff.com/shop/falcon ... p-122.html If it's a negative trigger (like mine which is incorporated with my alarm system.) will need to be converted using a relayStinch wrote:Hi ive been doing some research on this for our Bongo.
Scott which one did you buy out of interest? Did you go for a 4 door kit and use one of the actuators or buy the kit with out and buy an extra one to add on.
I want to do it cuse it's a pain to have to keep going round to the drivers door and it will be usefull to have the trunk release when im loading my bike in.![]()
Neal
Where as a remote CL system will at least unlock everything at the same time!
Just thought i'd set you up for what you might be in for fitting/installation wise!
Re: REMOTE LOCKING
There is a actuator in the boot, im not sure yet if the feed from the central locking feeds the side door before the back door or if there is a separate feed that goes to the back door from the dash...jaylee wrote:Neal, a separate trunk release will require an actuator & wiring through & into the tailgate..? Maybe using somthing like this..? http://www.in-car-stuff.com/shop/falcon ... p-122.html If it's a negative trigger (like mine which is incorporated with my alarm system.) will need to be converted using a relayStinch wrote:Hi ive been doing some research on this for our Bongo.
Nealhttp://www.the12volt.com/relays/page1.asp to actuate the boot.
If it goes directly from the dash then its a piece of cake to open the back door independently, cut the existing feed, wire in a diode (1N5408 will do) and put the new trunk release after this. The diode will stop the boot release feeding back and opening the doors too
In theory, I haven't checked the wiring yet though
スコット
スコット
Re: REMOTE LOCKING
Scott, good point!csmcqueen wrote:There is a actuator in the boot, im not sure yet if the feed from the central locking feeds the side door before the back door or if there is a separate feed that goes to the back door from the dash...jaylee wrote:Neal, a separate trunk release will require an actuator & wiring through & into the tailgate..? Maybe using somthing like this..? http://www.in-car-stuff.com/shop/falcon ... p-122.html If it's a negative trigger (like mine which is incorporated with my alarm system.) will need to be converted using a relayStinch wrote:Hi ive been doing some research on this for our Bongo.
If it goes directly from the dash then its a piece of cake to open the back door independently, cut the existing feed, wire in a diode (1N5408 will do) and put the new trunk release after this. The diode will stop the boot release feeding back and opening the doors too![]()
Sweet idea,
Re: REMOTE LOCKING
jaylee wrote:
Scott, good point!I was thinking more along the lines of an actual boot popper..
The type that pulls on the mechanism & free's the tailgate catch, then all you have to do is lift the tailgate.. Like on those fancy shmansy handle-less show cars??
Sweet idea,if there's a chance of doing it without pulling apart too much of the loom, or the head lining..?
Hmmmm, boot popper
I'm off to the drawing board
スコット
スコット
Stinch
Re: REMOTE LOCKING
Right click forgot to put the actuator in. So it will have to wait till next week.
Stinch
Re: REMOTE LOCKING
Fitted today, super easy thanks to your advice and no scraped knuckles
Cheers guys
Cheers guys
Re: REMOTE LOCKING
Great news! Locks with quite a solid clunk don't it.?
Re: REMOTE LOCKING
solid ??? The earth shakesjaylee wrote:Great news! Locks with quite a solid clunk don't it.?
スコット
スコット
