MAJOR FAULT ON BONGO OXFORD AREA
candp
Post by candp » Mon Nov 23, 2009 12:31 pm
Dear Someone Techie
Our bongo of a few months old (to us - is is S reg) suffered significant overheating on Friday. It needs capable attention, and probably quite a lot of a. Does anyone know of a good local specialist. We are in N Oxford area.
thankyou
C
Re: MAJOR FAULT ON BONGO OXFORD AREA
Post by francophile1947 » Mon Nov 23, 2009 12:43 pm
Welcome to the madhouse :D :D
There's a database of approved/recommended garages in the Member's Area 8)
How bad was the overheat? Did you have a low-coolant alarm fitted?
New Forest Terrier
Post by New Forest Terrier » Mon Nov 23, 2009 1:54 pm
Hi Canndp
Welcome but sad to have a first post from such a situation. :(
If you have recovery, Discount Trucks between Newbury and Andover is the South's expert on all Bongo problems. If Fred and Gerry cannot fix it no one can =D> They are thoroughly nice guys and total pros with overheating Bongos.
The important thing is not to drive it until the problem is sorted out. Assuming its a diesel, the engine is very vulnerable to a cracked head and needs the problem sorting ASAP.
The BewilderBeast - V6 Mean Green Tintop with LPG and 321 Away Montague Conversion
scanner
Post by scanner » Mon Nov 23, 2009 1:56 pm
Discount Trucks at Newbury is the closest I can think of with a good reputation for fixing thing right and first time.
Edit
Beaten to it..................
MondoBongo
Post by MondoBongo » Mon Nov 23, 2009 7:56 pm
get some kind of low coolant alarm fitted pronto. Haydn Callow sells one for about £80.
We've just had our second cylinder head replacement. That cost about £2400. (for both)...
candp
Post by candp » Wed Dec 09, 2009 9:13 pm
I will speak to Discount Truck guys, they sound like they know what they are doing. Thank you very, very much. C
Post by Bob » Wed Dec 09, 2009 11:29 pm
The Gang beat me to it, Discount Trucks.
Welcome, and good luck.
