silly question - where is the jack?
karlos
Post by karlos » Fri Nov 20, 2009 4:02 pm
Taking a group of friends out tommorow - dont want to come unstuck!
Where is the jack normally found looked in the obvious places (like in other vans) --except obviously not behind or under the front seats-.
No voids in drivers or passenger foot well or space behind lower dash not in bonnet? I'm sure the guy said it had one. I presume the jack handle doubles up as the tool to wind the spare wheel down?
diamond
Re: silly question - where is the jack?
Post by diamond » Fri Nov 20, 2009 4:05 pm
under the sliding door step ?
westonwarrior
Post by westonwarrior » Fri Nov 20, 2009 4:06 pm
sliding door well
behind a tool box cover is the jack extension arm and tool kit
Post by Bob » Fri Nov 20, 2009 4:16 pm
Extension bar is often clipped to the 'Roof' of this little cubby hole, and not immediately obvious.
karlos
Post by karlos » Fri Nov 20, 2009 4:34 pm
why didnt I think of that.
-found it (thats what I expected to find in the driver footwell or passenger) I supose taking into account the engine position and design of the engine bay not possible.
I dont think I've got the stock kit though.
1)a blue small bottle jack
2)a (cheap)half inch drive rachet with a normal length handle with no extension bar(no clearance between the handle and wheel) - obviously the rachet will give up the first time I have to step on it if the wheel nut's have not been off in a while.
3)what looks like a home made tyre lowering device -in a thin wall tube that you have to put a screwdriver throught to turn.(does fit the vans lowering system though)
"This is not what I expected to find - having owned and driven more than just a few vehicles with this kind of spare wheel system and ground clearance!
I expect at least some if not all of this is not genuine.
might chuck in my braker bar and small trolley jack just incase for now! (infact I will do it now before I forget)
Thanks again guys!
westonwarrior
Post by westonwarrior » Fri Nov 20, 2009 4:38 pm
no after market im afraid
stock kit is a scisor jack
stilldesperate
Post by stilldesperate » Fri Nov 20, 2009 4:42 pm
Hi Karlos,
There's some photo's of the bits HERE
Enjoy your trip!
SD
"The older I get, the faster I was"
daveblueozzie
Post by daveblueozzie » Fri Nov 20, 2009 5:43 pm
this is what you should have, with the long bar clipped onto the roof of the step.
Lost without my Bongo.
Post by Bob » Fri Nov 20, 2009 11:42 pm
This kit does come available (worth trying the known breakers) should you want it, but I'd just cary a trolley jack and socket set.
You'll need the extension bar for lowering the spare, but it's easily fabricated.
