Hold Light flashing and Speedo not working
mike2564
Post by mike2564 » Wed Sep 09, 2009 5:16 pm
Any ideas, got up this morning, Bongo started fine, and was performing ok, the hold light began to flash and the speedo stopped working. I switched it off and re started further down the road.. now all ok... why? Mike
Re: Hold Light flashing and Speedo not working
Post by mikeonb4c » Wed Sep 09, 2009 5:34 pm
mike2564 wrote:Any ideas, got up this morning, Bongo started fine, and was performing ok, the hold light began to flash and the speedo stopped working. I switched it off and re started further down the road.. now all ok... why? Mike
Have a search on here but I recall it being explained that the autobox takes a signal from the speedo. If the speedo has been 'chipped' to get KPH into MPH and if a connection goes dodgy (or summat like that) then the autobox gets a dodgy signal and the HOLD light registers a fault. Should not be a serious thing to get fixed but have a search for best advisce on what to do.
Good luck - keep us posted. 8)
bongomaan
Post by bongomaan » Wed Sep 09, 2009 9:31 pm
i have had this problem and with dandywarhols help traced it to the middle temp sensor in the head,regards neil...
Matt&JoyBongling
Post by Matt&JoyBongling » Thu Sep 10, 2009 9:52 am
If you have installed any electrical items connecting to the back of the dash - E.g some alarms, speedo chip, check that the connections are still OK - I had problem with mine which was down to a dodgy connection. All sorted now.
Underground, Overground, Bongoling Free, the Bonglers of Bedford, common are we ...
mike2564
Post by mike2564 » Wed Sep 23, 2009 1:13 pm
Hey thanks all for your advice, it seems to be behaving itself, but i will know where to look if it fails again. Thanks again Mike Off to Bala For the weekens... yipee!
vanvliet
Post by vanvliet » Wed Sep 23, 2009 10:43 pm
This happened to me - dodgy speedo connection. Hard thump on the dash top above the speedo fixed it - for a while - until I got around to (carefully) tightening the connections
Origo bio stove - no Bongo!
moonshine
Post by moonshine » Wed Sep 23, 2009 10:48 pm
I had this same problem too, and my speedo was fitted with a chip. It only occurred once in a while, and when it did I just switched the ignition off and re-started the engine. Cured it every time. Eventually I fitted a speedo from a Mazda 626 and it never happened again.
D n D & K
Post by D n D & K » Thu Sep 24, 2009 3:13 pm
same thing happens here from time to time but as said just restart and all is ok so we dont worry about it
hembramacho
Post by hembramacho » Thu Sep 24, 2009 8:33 pm
mike2564 wrote:Hey thanks all for your advice, it seems to be behaving itself, but i will know where to look if it fails again. Thanks again Mike Off to Bala For the weekens... yipee!
We're off to Bala this weekend also - may see you around. We're in a white AFT.
Andrew
