Wind noise from tops of doors
EddyH
Post by EddyH » Sun Sep 06, 2009 10:07 pm
Our Bongo seems to suffer from excessive wind noise around the tops of the doors. Is this a known problem and is there an easy fix?
Re: Wind noise from tops of doors
Post by missfixit70 » Sun Sep 06, 2009 10:11 pm
I think this is reasonably common, noticed mine starting to get a bit draughty. I seem to remember someone, Bigdaddycain I think, rolling the window down & applying a bit of leverage to the top of the door to bend it in a smidge, haven't got around to trying it myself yet.
brorabongo
Post by brorabongo » Sun Sep 06, 2009 10:20 pm
Suffer from the same, but just at speed with the wind in the right direction. I too hav'nt tried bending the frame a little. ( keep on forgetting to do so :roll: )
I wonder if the wind deflectors make it worse?
ボンゴの激怒 pictures
Post by missfixit70 » Sun Sep 06, 2009 10:21 pm
brorabongo wrote:Suffer from the same, but just at speed with the wind in the right direction. I too hav'nt tried bending the frame a little. ( keep on forgetting to do so :roll: )
I seem to remember this was a theory put forward before.
Found it :wink: - http://www.igmaynard.co.uk/bongo/forum/ ... amp%3B+gap
Post by mikeonb4c » Sun Sep 06, 2009 10:24 pm
Lots of discussion about that on here in the past - have a search. Some seem to get it more than others. I've only had it once I think (on my drivers side door) when a good wind was blowing 45 degrees or so across my left bow and travelling at 65 mph or so. Fully healthy Bongos don't seem to get it 8)
EddyH
Post by EddyH » Sun Sep 06, 2009 10:28 pm
mikeonb4c wrote:Lots of discussion about that on here in the past - have a search. Some seem to get it more than others. I've only had it once I think (on my drivers side door) when a good wind was blowing 45 degrees or so across my left bow and travelling at 65 mph or so. Fully healthy Bongos don't seem to get it 8)
I did a search and only found threads regarding wind noise from roof racks.
Our Bongo suffers on both doors. It is probably only at 60 and above but seems to occur quite often.
Sat inside with the doors closed I can fit my fingers in the gap at the top between the door frame and vehicle body.
Post by missfixit70 » Sun Sep 06, 2009 10:29 pm
See my link above :wink:
brorabongo
Post by brorabongo » Sun Sep 06, 2009 10:36 pm
mikeonb4c wrote: I've only had it once I think (on my drivers side door)
Only drivers door for me aswell.
ボンゴの激怒 pictures
EddyH
Post by EddyH » Sun Sep 06, 2009 10:39 pm
missfixit70 wrote:See my link above :wink:
Thanks, sounds like I need to try bending the tops of the doors and put some vaseline on the seals.
just to add I can get my fingers in the gap whether the car is doing 60 or is stationary.
Post by mikeonb4c » Sun Sep 06, 2009 10:53 pm
Haven't tried doing that with mine but something doesnt sound right. Proceed with caution on door bending. Maybe PM bigdaddycain (if it was he who tried it) and ask his advice on how best to do it before rushing ahead [-o<
sparkymik
Post by sparkymik » Sun Sep 06, 2009 10:55 pm
Mine rattles like it's on re-entry at speeds of over 80 not that I go there often
Sparky
The Bongo has gone. Long live The Bongo
Hymer Camp Swing 544/Fiat Ducato 2.3jtd
brorabongo
Post by brorabongo » Sun Sep 06, 2009 11:04 pm
sparkymik wrote:Mine rattles like it's on re-entry at speeds of over 80 not that I go there often
Sparky
Yeah, only happens on "track days" eh. :wink: :lol:
ボンゴの激怒 pictures
sparkymik
Post by sparkymik » Mon Sep 07, 2009 4:10 am
There's a thought track day for Bongo's, Santa Pod maybe :shock: :lol:
Sparky
helen&tony
Post by helen&tony » Mon Sep 07, 2009 5:53 am
Do NOT put vaseline on door rubbers...it can cause a breakdown of the seal...if anything, use rubber lubricant, or preferably, talc. in dry weather
Post by bigdaddycain » Mon Sep 07, 2009 8:00 pm
The top sections of the doors are surprizingly flimsy, and are quite easily "teased" back a tad... I only suffered it on my drivers door, and i only tickled it back just the once,which seemed to do the trick!
Open the door,grab just above the handle with your right hand, getting ready to pull...Grab the door top with your left hand ready to push...Use the same amount of force on the top and the middle,then tease it till you see the door "arc". Please do open your window fully, and i take no responsibility for the window shattering, or you injuring yourself! :shock: [-X Just try it a smidge at a time, and keep getting back in the bongo to visually check the gap, and to check that the door closes just as easily as it did beforehand :wink:
