refuel !!!!!
daznotts62
Re: refuel !!!!!
Post by daznotts62 » Fri Sep 04, 2009 8:57 pm
thanks kirsty
gonna delve a little deeper in the morning...............let it run out of fuel i think,maybe a dodgy gauge,clutching at straws at the mo !!!!!
Re: refuel !!!!!
Post by missfixit70 » Fri Sep 04, 2009 9:03 pm
Can you get to the top of the sender? This thread'll point you in the right direction http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=33920 At least then you'll be able to see what you've got in the tank & access the other end of the breather.
peanutcrusher
Re: refuel !!!!!
Post by peanutcrusher » Fri Sep 04, 2009 9:06 pm
try putting an endoscope do the filler tube then you can see into the tank then you know if its full of fuel or if there is a blockage you find with the hose pipe.
Bongo now work later !!! :) :)
Re: refuel !!!!!
Post by bigdaddycain » Sat Sep 05, 2009 10:48 am
Is there an anti-gravity force field at your filling station? :shock: I must admit, after many years of browsing the forum, i've never heard of this particular problem arising before with a bongo... This is a long shot... Have you tried just "dribbling" the fuel in? I know it'll be slow, but it's gotta be quicker than pushing a two ton bongo home! Occasionally, (with my car) if i try to fill up in a hurry, the "full tank" trigger click on the diesel pump will kick in repeatedly if i do a "full trigger!" pump... I then frustratingly "tickle" the trigger till i get a couple of quid in, then slowly increase hand pressure till i get a full flow.... I know, the words "straws" and "clutching" springs to mind :?
daznotts62
Re: refuel !!!!!
Post by daznotts62 » Sun Sep 06, 2009 9:02 am
oh dear do i feel silly..........it was afull tank of fuel with a dodgy gauge...........not had it long and not put much fuel in,must have been half full all along............thanks everyone for your help........getting fuel gauge sorted today (went to whitby on an empty tank !!!!!!!!)
thanks Daz
daveblueozzie
Re: refuel !!!!!
Post by daveblueozzie » Sun Sep 06, 2009 9:33 am
nuff said.
Lost without my Bongo.
Re: refuel !!!!!
Post by missfixit70 » Sun Sep 06, 2009 12:38 pm
:lol: =D> =D> Gold star for DBO :wink: I couldn't really see how it could be anything else from what you'd done.
Nearly as bad as the time I ended up taking off the fuel pump on my cavalier as it didn't seem to be getting fuel through, only to realise the tank was empty :oops: :lol: Sometimes we start looking for the more complex answers before checking the simple ones :wink:
Re: refuel !!!!!
Post by bigdaddycain » Sun Sep 06, 2009 2:52 pm
daznotts62 wrote:oh dear do i feel silly..........it was afull tank of fuel with a dodgy gauge...........not had it long and not put much fuel in,must have been half full all along............thanks everyone for your help........getting fuel gauge sorted today (went to whitby on an empty tank !!!!!!!!)
thanks Daz
No harm done Daz! I usually find that my tank is LOWER than expected, so that's a bonus i guess! :wink:
Re: refuel !!!!!
Post by missfixit70 » Sun Sep 06, 2009 4:38 pm
Not often a problem leaves you £60 better off :wink: :lol:
daznotts62
Re: refuel !!!!!
Post by daznotts62 » Sun Sep 06, 2009 8:00 pm
thanks again all ,that was a lesson learned i think............check the obvious !!!!!!!!!
Daz
