Anyone got any ideas whether it is possible to get a replacement?
Andrew
Thanks for that, though at £140crazy uncle gray g wrote:Andrew, if you take your Bongo along to a main mazda dealer,
they should be able to get all the information they need to get you a replacement central locking fob.
Do expect to pay around £140 though, I think that was what it cost me once for a ford transit
Thanks for the reply. I'm still thinking of doing the alarm thing at some point so if you could point me in the direction of someone local who could do it that would be great.stringman wrote:Regards your question about linking an alarm into your existing remote system the answer is yes. Its a good idea as the Mazda factory remote is not very reliable and you should be able to get an alarm fitted which will give you two brand new remotes as well as the additional security for around a couple of hundred quid.
I know a bloke in north wales who could do it if you want!
My fob's like that, and I managed to get a spare one from ebay. Never managed to program it thoughAlison01326 wrote:Delighted that you have found it, Hembramacho.
As I had already dug this out before you found it, I thought I'd post it anyway in case it's ever of interest to anyone else.
I assume this is the key fob in question (top left)?
and I imagine that the number below it is the part number (G06T V7 601). If not, the numbers S09A V7 600 and S09A V7 600R also appear on the document at what I imagine may be the front cover.
Hope this helps someone sometime
Thanks for that Alison. Would have acknowledged sooner but only arrived back from a trip in the Bongo!Alison01326 wrote:Delighted that you have found it, Hembramacho.
