AFT
wyefish
AFT
Post by wyefish » Wed Aug 19, 2009 5:46 am
AFT noisy operating. Is it OK to lubricate? If anyone has any info would be grateful.
Ron Miel
Re: AFT
Post by Ron Miel » Wed Aug 19, 2009 5:54 am
wyefish wrote:AFT noisy operating. Is it OK to lubricate? If anyone has any info would be grateful.
Thinly spread some Vaseline (all I had to hand, on a campsite - carry it, to keep rear window catches easy for Mrs M to work) on the runners on ours, and that did the trick but whether it has any adverse side effects, can't say. Was once told on here that using Vaseline to make the side door open/close smoother, would cause collection of grit, sand, etc. - it hasn't.
wyefish
Re: AFT
Post by wyefish » Wed Aug 19, 2009 6:03 am
Thanks for that! Sounds worth a try. I was wondering if WD40 might be an idea?
Ron Miel
Re: AFT
Post by Ron Miel » Wed Aug 19, 2009 6:06 am
wyefish wrote:Thanks for that! Sounds worth a try. I was wondering if WD40 might be an idea?
Am sure WD-40 would do the trick short term but the effect of Vaseline, or any grease for that matter, will last longer.
wyefish
Re: AFT
Post by wyefish » Wed Aug 19, 2009 6:11 am
Thanks Ron! Will go with the vaseline.
haydn callow
Re: AFT
Post by haydn callow » Wed Aug 19, 2009 10:06 am
White Lithium greese (Halfords) is less likely to mark the AFT material....works well.....clean all the runners first with White sprite
http://www.coolantalarm.co.uk
Also BMW Clocks
scanner
Re: AFT
Post by scanner » Wed Aug 19, 2009 10:20 am
haydn callow wrote:clean all the runners first with White sprite
What that fizzy stuff?
Ron Miel
Re: AFT
Post by Ron Miel » Thu Aug 20, 2009 12:07 am
haydn callow wrote:White Lithium greese (Halfords) is less likely to mark the AFT material....works well.....clean all the runners first with White sprite
Thanks for that tip Haydn. Will get some tomorrow, and clean off the Vaseline.
tricky
Re: AFT
Post by tricky » Thu Aug 20, 2009 5:11 pm
Screwfix are doing a PTFE spray lube. We used to use one of these (from RS I think) when I worked as an engineer to keep robot end tooling running smoothly where we couldn't risk grease as we were assembling camera shutters.
