Rear Power socket failure
Help, I have lost power to my rear power socket/ciggy lighter, this runs off my leisure battery apparently, need it working by the weekend as there are no electric hook-ups at Beautiful Days.
Re: Rear Power socket failure
I had the same go on mine when I accidentally overloaded it pumping up my tyres with a compressor. Its a bit hard to explain but take it out (push from the rear) and there is a little fuse wire that is soldered across two contacts on the bottom, its probably blown. Easy to do, just solder a new bit in, 5 min job. I cant remember what rating wire it is but just compare the thickness to a new bit.
Hope this helps and makes some sense!........
