Glowplug Light and Fuses
westonwarrior
Re: Glowplug Light and Fuses
Post by westonwarrior » Tue Aug 04, 2009 10:13 pm
The answer is both probably make the glow plug light flash if there is a problem
the warning system on bongos are very strange so if the light flashes it could be either sensor or connector scavenger (next to handbrake) or rad fan ( block )
they are also probably linked in some way
jaylee
Post by jaylee » Tue Aug 04, 2009 10:20 pm
Hey don't forget the connector just behind the bottom edge of the steering cowl Rob! :wink:
Yes, there are two paths you can go by
But in the long run
There's still time to change the road youre on.
OOOOH... It makes me wonder.... :-"
westonwarrior
Post by westonwarrior » Tue Aug 04, 2009 10:23 pm
do you often quote Rolf Harris?
two little boys?
jaylee
Post by jaylee » Tue Aug 04, 2009 10:37 pm
I gotta flashing glow light on my 3 litre roo...
Can you guess what it is yet? :lol:
kelv
Post by kelv » Tue Aug 04, 2009 10:52 pm
missfixit70 wrote:Start a different thread to answer those questions (or do a search - the answers are out there if you are that interested), refer to the original query & my comments about keeping it on track please.
I thought you would have had the answers too :(
Never mind.
kelv
Post by kelv » Tue Aug 04, 2009 10:53 pm
westonwarrior wrote:The answer is both probably make the glow plug light flash if there is a problem
Thanks, a useful answer.
jaylee
Post by jaylee » Tue Aug 04, 2009 10:58 pm
I do have another idea...! :D
It could be that old family favourite...
Um diddle iddle iddle um diddle eye!!! The old fault code... As i travel down the frog & toad..
What i get is an old fault code.....
kelv
Post by kelv » Tue Aug 04, 2009 11:00 pm
jaylee wrote:I do have another idea...! :D
Have you got one for Jake the Peg as well ?
:D
But make it on topic for crying out loud , anybody got any Meerkats ? :lol:
jaylee
Post by jaylee » Tue Aug 04, 2009 11:14 pm
kelv wrote: Have you got one for Jake the Peg as well ?
:D
Don't tell me your still trying to sort out the cruise control & you need an extra leg...!
kelv
Post by kelv » Wed Aug 05, 2009 8:17 am
:D
Nope, I binned that heap of junk :lol:
Couldn't get it to remove the Mondeos that kept cutting in front of me and making me switch it off :wink:
Post by missfixit70 » Wed Aug 05, 2009 12:32 pm
This may be of interest - http://www.igmaynard.co.uk/bongo/forum/ ... an+testing, Dandy & G8DHE's input about halfway down the 3rd page in particular - highlighting the complexity of the fan trigger system.
If sensors & connections have been checked/replaced & any other suggested causes checked, then the next logical step is to use the Diagnostics factsheet or take it to a garage that can plug in a OBD II Diagnostic jobby IMO.
kelv
Post by kelv » Wed Aug 05, 2009 1:32 pm
missfixit70 wrote:This may be of interest - http://www.igmaynard.co.uk/bongo/forum/ ... an+testing, Dandy & G8DHE's input about halfway down the 3rd page in particular - highlighting the complexity of the fan trigger system.
Yes, probably not worth messing about shorting out sensors to check the operation of the scavenger fan then :!:
To test mine, I got the engine hot, then unplugged the sensor.
The glowplug light flashed a bit, then the rad fan cut in, followed by the scavenger fan, which could be seen but not heard.
I guess that it is working as it should be, and you would probably never know with the seats down.
A flashing glowplug light does in some way seem to be linked to the fan sensor.
Mine stopped flashing again when the sensor was plugged back in.
Post by Doone » Wed Aug 05, 2009 9:25 pm
In case anyone is looking for this info in future, I understand that the photo in THIS LINK (from 'stilldesperate') is the scavenger fan sensor. The one in THIS LINK is the engine cooling (radiator) fan sensor.
kelv
Post by kelv » Wed Aug 05, 2009 9:30 pm
Doone wrote:In case anyone is looking for this info in future, I understand that the photo in THIS LINK (from 'stilldesperate') is the scavenger fan sensor. The one in THIS LINK is the engine cooling (radiator) fan sensor.
Thanks for pics :D
westonwarrior
Post by westonwarrior » Wed Aug 05, 2009 9:38 pm
Depends what the pictures are of
Thats why I stopped getting the Sun it didnt help my reading at all.
I do think that little comments in other wise reasonable questions and answers are unnecessary and are getting noticed.
