won't start !! please help
- peanutcrusher
- Tribal Elder
tried to start but will no joy all the lights on the dash come on as the should, turn the key the engine trys to turn over then all you get is a clicking noise, tried jump starting the same thing happens can anyone help
Bongo now work later !!!
- westonwarrior
Re: won't start !! please help
it doesn't turn over then its the starter contacts
easy fix but you need the contacts
info on this thread
http://www.igmaynard.co.uk/bongo/forum/ ... r+contacts
info on this thread
- brorabongo
If your lucky you might be able to clean the contacts a little to get you going for now...it worked for me.
- missfixit70
Mine worked for a couple of weeks by giving the starter a few gentle taps with a hammer before giving up totally, by which time the contacts & plunger had arrived, dead easy job to do - about half an hour from lifting the drivers seat to trouble free starting.
Check the voltage at the starter, just in case, even jump starting sometimes doesn't make proper contact.
- peanutcrusher
- Tribal Elder
all sorted
thanks to everyone who replied, turn out that when the recovery lorry turned up it started on his booster pack first time. turns out the alternator had stopped work so there was enough power to light up the dash but not to turn it over. got it recovered to discount trucks. phone to see if the van had turned up only to be told by fred it's finish and ready for collection now how's that for service. big thanks to gerry and fred I can now go on holiday tonight
