First thing in the morning or when cold my Bongo remains in first gear until she warms up. Also stalls if I have the audacity to try to slow her down by pressing the brakes.
Once warm she is wonderful. 4x4 Diesel 2.5 TD. 1999 reg.
New Forest area.
My Bongo is a witch when cold.
- Location: in a place far, far away, well Somerset for now!!!
Re: My Bongo is a witch when cold.
are you sure she's stAying in first gear as they all need to warm up before changing all the way up through the box a few miles at least then into top gear once warmed up??? more info needed I think before we can tell for sure??
Until the thermostat gets up into the warm area she doesn't change gear. She also seems to race away and if I use the brakes to control her sh tends to stall.
Regards,
BoB.
Regards,
BoB.
- You've Been Bongod
have you checked your gearbox fluid level???
maybe it needs changing
my bongo and many others dont change gear properly until warmed up but that used to only happen in the winter
Many thanks. Will check and change as necessary and see if it cures it.
BoB.
BoB.
