Bongo is making a humming noise
Hi, not sure if anyone can help remotely, but the Bongo is making a humming noise when it gets to 40 mph, it goes if I go much faster and doesn't happen any slower. Any ideas about what it could be?
Its a 96 automatic diesel if that helps.
- westonwarrior
Re: Bongo is making a humming noise
I would guess at wheel bearings but have no idea realy
- haydn callow
Tyre noise ??
It isn't pulling or anything and it just went through an mot, though they thought the exhaust was blowing a little but was sooted up. Could the exhaust be making the noise?
I'll get the wheel bearings checked, thanks
Is that expensive by the way? Being a lass I always like a ball park figure before I go to a garage or they tend to do much in drawn breath through the teeth!
Last edited by technobollocks on Mon Jun 29, 2009 8:57 pm, edited 1 time in total.
- mister munkey
Transmission whine is my bet. Check/change fluid for starters.
Is that the gear box fluid you mean?
Check it all g/box and all the diffs
Other wise it may not know the words.
F Zappa
F Zappa
Very good Lizardlizard wrote:Check it all g/box and all the diffs
I did wonder if there was a bee sting Ariel fitted
sorry about that, it just tickled my laughing gear.
Nick
Welsh Winger
You can get a beasting in the Armywelsh winger wrote:Very good Lizardlizard wrote:Check it all g/box and all the diffs
Other wise it may not know the words.![]()
I did wonder if there was a bee sting Ariel fitted![]()
Nick
Welsh Winger
F Zappa
F Zappa
I am getting the same problem if you solve it let me jnow what it is .
Georeg Roberts 01691 773955
Same noise as you checked tyre pressures one tyre really low put 32 in front 34 in back went for a test drive noise gone.it,s a lot more peaceful now.
George
George
HAve a look at the tread on your front tyres - they can have flat spots and rasied tread - mine has always done it and can cause a thrumming noise as you go along. I understand it's a sign of vc on the way out - but I've had mine for over four years and its still okay - very quickly touches a bit of wood.
I'm not fitting van tryes next time too.
And 205's all round I think.
