Mystery Leak - to me anyway!
Good Morning,
Can anyone help?
Beneath my Bongo from the drivers side there a leaky (flexible?) pipe which I think comes from the front and enters what I would call a sump - just to the right of the auto cable lever.
Is there a simple way to change this pipe without the fluid going everywhere?
What is this pipe?
Where do I top up any loss or refill (and with what?).
Any info would be very helpful.
Rob
(off for some food now, will be back)
Can anyone help?
What is this pipe?
Rob
Re: Mystery Leak - to me anyway!
There are a lot of pipes on a Bongo
Might help if you could put up a picture, I assume its a diesel and not a V6 ? What is the substance that's leaking, is it coloured, does it smell ?
- haydn callow
I think you could be talking about the TOP HOSE (cylinder head to metal pipe)
If this is the case you will lose a large amount of coolant when you replace it.
Do not attempt this job unless you are 100% sure you know how to bleed the cooling system when you refill.
DO NOT take it to "any old" garage to have the job done unless they have worked on Bongos before.
Be Warned !!! Bongos are not the same as the normal vehicles they work on and if this job is not done correctly it can cost loads in repairs.
Thanks,
I may have mislead you. Here are a couple of pics that will explain it much better.
Thanks again, Rob.
???? How on earth do I load pictures ????
Thanks again, Rob.
- westonwarrior
http://www.igmaynard.co.uk/bongo/forum/ ... 85&start=0
the you tube link does not work but you copy the given link in photobucket and past it in the message
Hi Westernwarrior,
Thanks for "the you tube link does not work but you copy the given link in photobucket and past it in the message" BUT I am very new to this and so if you could translate into Basic English I might be your debt forever.
Rob
Rob
[url][/urhttp://s926.photobucket.com/albums/ad105/Mibongo_photos/l]
Tried to load pics again and again and again .......
HELP !!!!!!!!
Now going for a pint!
HELP !!!!!!!!
- maxheadroom
- maxheadroom
PS I think your picture maybe to big for the forum, only allow max 640 x 640 pixels
but try this link...
http://s926.photobucket.com/albums/ad10 ... eak004.jpg
- mister munkey
- haydn callow
ATF fluid.....
I was thinking top hose till i saw the picture...mister munkey wrote:
That the gear oil pipe that goes to the section at the bottom of the radiator to cool the fluid down??
...Or has my complete lack of techie knowledge shone forth again!?
Thanks to everyone!
So if it's ATF can the pipe be easily changed?
Or should I remove the pipe, replace, drain the lot and refill?
Rob
Rob
