Mystery Leak - to me anyway!
Mibongo
Post by Mibongo » Sun Jul 05, 2009 8:05 am
Good Morning,
Can anyone help?
Beneath my Bongo from the drivers side there a leaky (flexible?) pipe which I think comes from the front and enters what I would call a sump - just to the right of the auto cable lever.
Is there a simple way to change this pipe without the fluid going everywhere?
What is this pipe?
Where do I top up any loss or refill (and with what?).
Any info would be very helpful.
Rob
(off for some food now, will be back)
Re: Mystery Leak - to me anyway!
Post by g8dhe » Sun Jul 05, 2009 11:35 am
There are a lot of pipes on a Bongo :!: Might help if you could put up a picture, I assume its a diesel and not a V6 ? What is the substance that's leaking, is it coloured, does it smell ?
haydn callow
Post by haydn callow » Sun Jul 05, 2009 12:20 pm
I think you could be talking about the TOP HOSE (cylinder head to metal pipe)
If this is the case you will lose a large amount of coolant when you replace it.
Do not attempt this job unless you are 100% sure you know how to bleed the cooling system when you refill.
DO NOT take it to "any old" garage to have the job done unless they have worked on Bongos before.
Be Warned !!! Bongos are not the same as the normal vehicles they work on and if this job is not done correctly it can cost loads in repairs.
http://www.coolantalarm.co.uk
Also BMW Clocks
Mibongo
Post by Mibongo » Sun Jul 05, 2009 12:58 pm
Thanks,
I may have mislead you. Here are a couple of pics that will explain it much better.
Thanks again, Rob.
???? How on earth do I load pictures ????
westonwarrior
Post by westonwarrior » Sun Jul 05, 2009 1:06 pm
http://www.igmaynard.co.uk/bongo/forum/ ... 85&start=0
the you tube link does not work but you copy the given link in photobucket and past it in the message
Mibongo
Post by Mibongo » Sun Jul 05, 2009 1:42 pm
Hi Westernwarrior,
Thanks for "the you tube link does not work but you copy the given link in photobucket and past it in the message" BUT I am very new to this and so if you could translate into Basic English I might be your debt forever.
Rob
Mibongo
Post by Mibongo » Sun Jul 05, 2009 2:26 pm
Mibongo
Post by Mibongo » Sun Jul 05, 2009 2:42 pm
[url][/urhttp://s926.photobucket.com/albums/ad105/Mibongo_photos/l]
Mibongo
Post by Mibongo » Sun Jul 05, 2009 2:44 pm
Tried to load pics again and again and again .......
HELP !!!!!!!!
Now going for a pint!
maxheadroom
Post by maxheadroom » Sun Jul 05, 2009 2:56 pm
That is gear box fluid
Keep the Faith
maxheadroom
Post by maxheadroom » Sun Jul 05, 2009 2:58 pm
PS I think your picture maybe to big for the forum, only allow max 640 x 640 pixels :D
but try this link...
http://s926.photobucket.com/albums/ad10 ... eak004.jpg
Keep the Faith
mister munkey
Post by mister munkey » Sun Jul 05, 2009 3:48 pm
haydn callow
Post by haydn callow » Sun Jul 05, 2009 4:00 pm
ATF fluid.....
Also BMW Clocks
jaylee
Post by jaylee » Sun Jul 05, 2009 4:00 pm
mister munkey wrote:Image
I was thinking top hose till i saw the picture...
That the gear oil pipe that goes to the section at the bottom of the radiator to cool the fluid down??
...Or has my complete lack of techie knowledge shone forth again!? #-o
Mibongo
Post by Mibongo » Sun Jul 05, 2009 5:29 pm
Thanks to everyone!
So if it's ATF can the pipe be easily changed?
Or should I remove the pipe, replace, drain the lot and refill?
Rob
