help passenger window stuck down
BrixhamBongo
Post by BrixhamBongo » Mon Jun 22, 2009 7:51 pm
got home just passenger window wont come up , checked i have got the switches in right postion , their ok , exposed loom between door and body thats ok , pulled off panel , cant see anything loose , the only thing i can hear is a clicking from the motor when i operate the switch ,
help please :oops: :oops: :cry:
waycar8
Re: help passenger window stuck down
Post by waycar8 » Mon Jun 22, 2009 8:40 pm
has it come out of the runner?, if its slightly off it might be fouling on something on the way up?
BrixhamBongo
Post by BrixhamBongo » Mon Jun 22, 2009 9:45 pm
waycar you could have been right :wink:
i came up with a bright idea :idea: , took the top part of the motor off on the passenger side , the plan was to swop it with the other side , when i came to do that i realised there were another couple of bolts i couldnt get too :roll: , so used the motor part to manually wind the window up , then put the motor back together , guess what when i reassmbled every thing it worked again ! :lol: , probably need another motor eventually
waycar8
Post by waycar8 » Mon Jun 22, 2009 9:59 pm
glad your sorted anyhow, if you need the motor, ive put a thread on stuff wanted thread, a guy giving away loads of bts and bobs from a bongo hes breaking free, he has the doors still so he might give you the motor from th window for cost of postage :wink:
BrixhamBongo
Post by BrixhamBongo » Mon Jun 22, 2009 10:14 pm
cheers i'll have a look
