What does this lot do? Diesel vacuum pump assembly.
Miles69
Post by Miles69 » Sun Jun 07, 2009 9:31 pm
Whilst doing some work on the bongo over the weekend I noticed that some of the vacuum tubes on the vacuum pump assembly weren’t connected or were missing. I’ve found this diagram (see link) and worked out tube 20-341 wont connect to Z as the end is broken of Z #-o , and that I’m missing tube 20-444 #-o (you can find these in the centre and top left part of the diagram). The car is running fine so I don’t understand what this lot do and what effect it has on the engine/performance/economy with them in their current condition :? . Can anyone shed any light on their role …
I know my description is all a bit techie but i haven't got a hope of explaing the parts without the diagram!
Thanks, M
http://www.lushprojects.com/bongopartsm ... 1of02.html
dreamwarrioruk
Re: What does this lot do? Diesel vacuum pump assembly.
Post by dreamwarrioruk » Sun Jun 07, 2009 9:35 pm
these are to do with the egr valve on the left and the right one is for the aircon.
mike, jo and emma
Miles69
Post by Miles69 » Sun Jun 07, 2009 9:38 pm
Does that mean my egr hasn't been working?
The aircon seems to be working fine - used it a lot last week.
dreamwarrioruk
Post by dreamwarrioruk » Sun Jun 07, 2009 9:42 pm
i take it that these are on the drivers side.
to stop the egr valve working people have put a ballbearing into the pipe to stop the vaccumm. the right one will lift the revs up slightly when the aircon comes on, thats all ive found but maybe someone else will be on to help you.
mike, jo and emma
Miles69
Post by Miles69 » Mon Jun 08, 2009 8:20 pm
OK. Thanks for that.
Just disabled the egr with a blanking plate so it wont make much difference.
Will check to see if my revs drop when i switch the aircon on - best repair the broken pipe to the right hand ones.
