Autoelectrics - What's this called?
dvisor
Post by dvisor » Thu May 14, 2009 2:21 pm
Can anyone tell me what this type of fuse holder is called? I'm trying to get hold of another one, as it looks like they are stackable and they mount directly to the battery terminal. I want to run a cable back into the cab, and this looks like it will be the neatest solution. Can't seem to find them on the net, but if I knew what they were called....Thanks.
Two tonne tin drum
dandywarhol
Re: Autoelectrics - What's this called?
Post by dandywarhol » Thu May 14, 2009 2:39 pm
An in-line fuse?
dvisor
Post by dvisor » Thu May 14, 2009 2:51 pm
dandywarhol wrote:An in-line fuse?
Yes, but I was after something more specific than that.
Two tonne tin drum
Post by missfixit70 » Thu May 14, 2009 2:54 pm
Give willinton a shout on ebay, I'm sure he'll be able to point you in the right direction or provide one for you.
Post by g8dhe » Thu May 14, 2009 5:05 pm
It looks like a Maxi size fuse, and yes they are stackable holders and they appear on EBay here
dvisor
Post by dvisor » Thu May 14, 2009 5:25 pm
g8dhe wrote:It looks like a Maxi size fuse, and yes they are stackable holders and they appear on EBay here
Thanks Geoff - that's certainly the type - I was hoping I could find one with the fixed battery terminal connector though. MaybeWillinton makes them up like that - I'll try contacting him through eBay like Kirsty suggested.
Two tonne tin drum
dandywarhol
Post by dandywarhol » Thu May 14, 2009 5:30 pm
Sorry - I wasn't being a smartarse - Martin at Willinton does make them that way.
stringman
Post by stringman » Fri May 15, 2009 6:53 am
If mounting under the bonnet you can get fully sealed waterproof versions of these which may be better. If going for a fuse box type arrangement why not use a waterproof fuse at the battery then run a cable from that to the inside (behind the glove box perhaps) and have a fuse box in the dry where it is less likely to corrode?
Tin top Bongo camper, Peugeot Partner Combi, Kawasaki ZRX1100, Yamaha SR250SE
dvisor
Post by dvisor » Fri May 15, 2009 7:18 am
stringman wrote:If mounting under the bonnet you can get fully sealed waterproof versions of these which may be better. If going for a fuse box type arrangement why not use a waterproof fuse at the battery then run a cable from that to the inside (behind the glove box perhaps) and have a fuse box in the dry where it is less likely to corrode?
Hi - yeah, that's pretty much what I've got planned. 40 Amp cable fused at battery, running through rubber grommet behind the expansion tank, to a 4 way fuse box mounted in the space behind glove box.
Two tonne tin drum
