When I remove the bits from under the passenger seat, would a new section of exhaust, without the valve, fit on?
SD
The winter pack on mine doesn't work (I tried it before I read about the danger of the valve sticking on!), but one of the rubber vacuum pipes has been disconnected (will have to have a look to check which one) & there are no effects on the rest of the running of the van.stilldesperate wrote:
It's not high on the list of jobs, I'm sure it'll run OK just with the control box under the seat removed, there's what I think is a vacuum pipe to disconnect - anyone suggest what to do with it![]()
SD
