correct speakers
peanutcrusher
correct speakers
Post by peanutcrusher » Sun Apr 19, 2009 8:40 pm
I've have managed to gain access to my speakers here are some pic
http://i86.photobucket.com/albums/k96/p ... 120447.jpg
http://i86.photobucket.com/albums/k96/p ... 120451.jpg
http://i86.photobucket.com/albums/k96/p ... 120452.jpg
http://i86.photobucket.com/albums/k96/p ... 120455.jpg
http://i86.photobucket.com/albums/k96/p ... 120456.jpg
Now the front one sound half descent, but the back one are very quite can anyone confirm from my pictures if the speakers look like the ones, that come standard in bongos or not.
The measurements are, front 6" and rear are 6" x 8"
Bongo now work later !!! :) :)
Action Ali-bongo
Re: correct speakers
Post by Action Ali-bongo » Sun Apr 19, 2009 8:54 pm
look like the standard bad boys to me mate, just changed all of mine :D
If i get any more stupid i will have to be watered twice a week!! :)
peanutcrusher
Post by peanutcrusher » Sun Apr 19, 2009 9:18 pm
are the front ones glued to the doors as well as screwed because i took the screws out, the speakers and they still will not budge.
i tried removing the screws into the door its self then the ones into the plastic outer but no joy :cry:
am i missing something.
Action Ali-bongo
Post by Action Ali-bongo » Sun Apr 19, 2009 9:45 pm
I took the speaker and the mounting pod out together, think you are right they are glued, i had to use a mallet on the magnet of the original speakers to free them from the mounting pod, which was no probs for me because i was replacing them anyways. I put some 16cm alpines in there, used that self adhesive draught excluder around the edge of the mounting pod before screwing the new speakers in to ensure a tight fit.
hope that helps, good luck :)
peanutcrusher
Post by peanutcrusher » Sun Apr 19, 2009 9:49 pm
cool now i know what to do next in the removal of the front ones what about the back ones are they glued too.
Action Ali-bongo
Post by Action Ali-bongo » Sun Apr 19, 2009 11:47 pm
From memory and it was two weeks ago! :lol: i think the rears just unscrew, and the mounting case stays in situ and you just un-plug and lift out the speakers.
Al
David Edwards
Post by David Edwards » Mon Apr 20, 2009 12:38 am
Getting at the rear ones is the problem, I have tried but cannot seem to remove the panel, there is no clearance with the seats, managed to get all but one screw out by reaching in with one hand and holding the panel back with the other but had to give up the damn screw would not budge. I am gonna try the front ones soon as the cannot cope with my dvd player.
Action Ali-bongo
Post by Action Ali-bongo » Mon Apr 20, 2009 9:18 am
Hi i have split rear seats and took them out before i removed the whole panel, easy to do just a couple of bolts on each seat and the bottom seat belt bolt then lift out whole seat. you can then get to all the screws and prize off the rear panel, be careful not to break the clips.
Al.
