bongo screaming!
carlod
bongo screaming!
Post by carlod » Thu Apr 09, 2009 4:44 pm
my bongo has developed an awful screech when accelerating, it sounds just like a belt slipping but a mechanic replaced the belts & the screech is still there, he said it could be the manifold where the exhaust meets, but I am not that confident in his abilities....has anyone come across this problem before?
Jolly Rogers
Re: bongo screaming!
Post by Jolly Rogers » Thu Apr 09, 2009 4:47 pm
carlod wrote:my bongo has developed an awful screech when accelerating, it sounds just like a belt slipping but a mechanic replaced the belts & the screech is still there, he said it could be the manifold where the exhaust meets, but I am not that confident in his abilities....has anyone come across this problem before?
Sounds like a stud in your manifold has snapped. Have you searched under snapped stud?
haydn callow
Post by haydn callow » Thu Apr 09, 2009 5:40 pm
No 1 manifold stud...The only you can see without dismantling. Just above and right of the Alternator..Easy fix by any half decent Mechanic..About 1-2 hours work. No need to remove anything...just remove the broken stud or perhaps drill out and helicoil.
http://www.coolantalarm.co.uk
Also BMW Clocks
David Edwards
Post by David Edwards » Thu Apr 09, 2009 6:12 pm
Had mine done last week, took a couple of hours thats all, cost me £30.00.
Jolly Rogers
Post by Jolly Rogers » Thu Apr 09, 2009 6:39 pm
Wow :shock: I amaze myself sometimes. If you would have asked the same question two yeards ago. I wouldn't have had a clue.. :lol:
I have learnt so much from you guys. =D> =D>
ScubaBongo
Post by ScubaBongo » Thu Apr 09, 2009 7:10 pm
David Edwards wrote:Had mine done last week, took a couple of hours thats all, cost me £30.00.
I wish I used the same garage as you David!
brorabongo
Post by brorabongo » Thu Apr 09, 2009 9:47 pm
I wish too! :lol:
ボンゴの激怒 pictures
lizard
Post by lizard » Thu Apr 09, 2009 11:21 pm
haydn callow wrote:No 1 manifold stud...The only you can see without dismantling. Just above and right of the Alternator..Easy fix by any half decent Mechanic..About 1-2 hours work. No need to remove anything...just remove the broken stud or perhaps drill out and helicoil.
Well, I am sure that mine's a bit different here. This photo shows a nice shiny silver engine with an arrow sticking out the side. When looking at the one I have, it's a nasty dull black with a murky grey hue. :lol:
F Zappa
