bongo screaming!
carlod
bongo screaming!
my bongo has developed an awful screech when accelerating, it sounds just like a belt slipping but a mechanic replaced the belts & the screech is still there, he said it could be the manifold where the exhaust meets, but I am not that confident in his abilities....has anyone come across this problem before?
Jolly Rogers
Re: bongo screaming!
Sounds like a stud in your manifold has snapped. Have you searched under snapped stud?carlod wrote:my bongo has developed an awful screech when accelerating, it sounds just like a belt slipping but a mechanic replaced the belts & the screech is still there, he said it could be the manifold where the exhaust meets, but I am not that confident in his abilities....has anyone come across this problem before?
- haydn callow
No 1 manifold stud...The only you can see without dismantling. Just above and right of the Alternator..Easy fix by any half decent Mechanic..About 1-2 hours work. No need to remove anything...just remove the broken stud or perhaps drill out and helicoil.
David Edwards
Had mine done last week, took a couple of hours thats all, cost me £30.00.
Jolly Rogers
WowJolly Rogers wrote:Sounds like a stud in your manifold has snapped. Have you searched under snapped stud?carlod wrote:my bongo has developed an awful screech when accelerating, it sounds just like a belt slipping but a mechanic replaced the belts & the screech is still there, he said it could be the manifold where the exhaust meets, but I am not that confident in his abilities....has anyone come across this problem before?
I have learnt so much from you guys.
ScubaBongo
I wish I used the same garage as you David!David Edwards wrote:Had mine done last week, took a couple of hours thats all, cost me £30.00.
- brorabongo
I wish too!ScubaBongo wrote:I wish I used the same garage as you David!David Edwards wrote:Had mine done last week, took a couple of hours thats all, cost me £30.00.
haydn callow wrote:No 1 manifold stud...The only you can see without dismantling. Just above and right of the Alternator..Easy fix by any half decent Mechanic..About 1-2 hours work. No need to remove anything...just remove the broken stud or perhaps drill out and helicoil.
Well, I am sure that mine's a bit different here. This photo shows a nice shiny silver engine with an arrow sticking out the side. When looking at the one I have, it's a nasty dull black with a murky grey hue.
F Zappa
F Zappa
