no ABS Light!
nattydread
no ABS Light!
Post by nattydread » Tue Mar 31, 2009 10:11 am
hi,
My van does not have a lit up abs light on the dash, this has never been there since i got my bongo 2 years ago and now its an issue with the MOT. Just a bulb in the dash or something more sinister?
cheers
Re: no ABS Light!
Post by missfixit70 » Tue Mar 31, 2009 10:57 am
Are you sure you have ABS? not all do.
Mr Halibut
Re: no ABS Light!
Post by Mr Halibut » Tue Mar 31, 2009 12:35 pm
yep, when i was looking at buying a Bongo it seemed prior to around 97/98 it was an option or just not fitted.
Re: no ABS Light!
Post by missfixit70 » Tue Mar 31, 2009 12:40 pm
Check whether it's got a fuse & connections in the appropriate fuse holder, diagram is in the factsheets in the members area.
nattydread
Re: no ABS Light!
Post by nattydread » Tue Mar 31, 2009 2:18 pm
cheers for the advice, i will have a look at the van later, the man at the garage seemed very sure that it had ABS when i had the MOT done, so apparently it does have ABS.... hmmmm
nattydread
Re: no ABS Light!
Post by nattydread » Wed Apr 01, 2009 11:17 am
just had a look at the van and there is an ABS fuse! does this mean it could be a light on the dash for the light of a failure of the ABS?
Re: no ABS Light!
Post by missfixit70 » Wed Apr 01, 2009 11:51 am
Could be the bulb's gone, or it was removed because there's a problem & the ABS light wasn't going out?
nattydread
Re: no ABS Light!
Post by nattydread » Wed Apr 01, 2009 11:54 am
any idea how i can get to the bulb? do i have to take out the dash?
scanner
Re: no ABS Light!
Post by scanner » Wed Apr 01, 2009 11:56 am
nattydread wrote:any idea how i can get to the bulb? do i have to take out the dash?
SFAIK it's the only way - but it's not difficult.
Re: no ABS Light!
Post by missfixit70 » Wed Apr 01, 2009 11:57 am
Yep, 4 screws holding in the binnacle surround, drop the steering wheel to its lowest adjustment & firkle the surround out then 4 screws holding in the console, you will probably have to unplug the ribbon cables (carefully).
nattydread
Re: no ABS Light!
Post by nattydread » Wed Apr 01, 2009 1:53 pm
dashboard out and back in, no probs.However after swapping a few bulbs about, it is prob the worst result :0( no bulb in the ABS slot and now the light is not going out....does this mean an expensive fault on the ABS?
scanner
Re: no ABS Light!
Post by scanner » Wed Apr 01, 2009 1:57 pm
nattydread wrote:dashboard out and back in, no probs.However after swapping a few bulbs about, it is prob the worst result :0( no bulb in the ABS slot and now the light is not going out....does this mean an expensive fault on the ABS?
That is the usual reason for the ABS bulb to be missing................. :?
nattydread
Re: no ABS Light!
Post by nattydread » Wed Apr 01, 2009 2:12 pm
whats best to do now? the local garage said its machine would not fit into the cables under the glove box so they could not work out the problem?
dandywarhol
Re: no ABS Light!
Post by dandywarhol » Wed Apr 01, 2009 2:19 pm
Problem often is a broken sensor wire going to the pickup at the wheels. All you need is an ohmeter and check for continuity at each sensor - you won't do any harm to the system.
