Passenger Side window help.
bongobong
Post by bongobong » Sat Mar 14, 2009 10:08 pm
The passenger side window on my bongo has stopped working. Everything else works. Any ideas what could be the problem :-k
Jolly Rogers
Re: Passenger Side window help.
Post by Jolly Rogers » Sat Mar 14, 2009 10:14 pm
It could be a few things
1) Hold switch on the Drivers switch on :oops:
2) Broken wire between the door
3) Dirty connections in switch
4) Broken switch
scanner
Post by scanner » Sat Mar 14, 2009 10:16 pm
Broken wire in the loom where it goes from bodyshell to door.
Common failure due to the tight cable tie thing that holds the loom to the hinge creasing the wires and they eventually break..
bongobong
Post by bongobong » Sat Mar 14, 2009 10:17 pm
Thanks for your reply,
I know its not the hold switch. Not hot on electrics, what the best way to go about tracing the fault?
steviebongo
Post by steviebongo » Sat Mar 14, 2009 10:50 pm
hi there see if there is any power at the n/s switch or earth for that matter?
jaylee
Post by jaylee » Sun Mar 15, 2009 1:15 am
Yep, try the passenger switch.. If that don't work either.
The driver door looms the best bet!! :wink:
Make sure to check the wire under the grommet cowling thing in the door & body panel as well as where the loom bends to the door hinge clip.. :wink:
wonkanoby
Post by wonkanoby » Sun Mar 15, 2009 8:35 am
wobble the loom around by drivers door
whilst some one holds the switch up is my bet to
