Removing seat sliders
Re: Removing seat sliders
You will probably need to loosen the rails from the Bongo floor, remove the end stops, and slide the runners off.
The end stop bit can be a pig to re-fit, but you can pop a bolt in it's place, just leave the nut loose/finger tight.
Good luck.
Good luck.
- missfixit70
This thread - here should help.
Welcome to the forum
Wherabouts are you? stick your location in your profile by clicking on "user control panel" top right.
