vague steering
meek.tv
vague steering
Post by meek.tv » Thu Feb 19, 2009 12:06 pm
noticed recently that the steering seems a bit more spongey and less sharp
wahst the usual culprits that could be causing these symptoms?
cheers
.......... cycling more.
Re: vague steering
Post by missfixit70 » Thu Feb 19, 2009 12:46 pm
Check the fluid level under the drivers seat (ATF ), if it's dropped - check for leaks.
meek.tv
Re: vague steering
Post by meek.tv » Thu Feb 19, 2009 1:03 pm
missfixit70 wrote:Check the fluid level under the drivers seat (ATF ), if it's dropped - check for leaks.
thanks for that, ill check at home (started riding the push bike to workie :S) is there diffrent grades of ATF? the guys in the unit opposite sell it, i might aswell pick some up just incase
Re: vague steering
Post by Doone » Thu Feb 19, 2009 4:26 pm
Just get a good quality ATF. If it's not leaking, the ATF can deteriorate and should be changed approx every 2 years.
meek.tv
Re: vague steering
Post by meek.tv » Thu Feb 19, 2009 4:36 pm
all they had over in the other unit was PSF (power steering fluid) it says its compatible with most ATF's......should be ok right? :S
The Great Pretender
Re: vague steering
Post by The Great Pretender » Fri Feb 20, 2009 12:34 am
Have you looked at the anti roll bar bushes and links, the Bongo will wallow around corners and over dips and bumps if they are shot. :wink:
To infinity and beyond
mister munkey
Re: vague steering
Post by mister munkey » Fri Feb 20, 2009 12:36 am
Another obvious is tyre presures.
Mine had dropped by 10 psi since christmas, much better with a pump up. . . . .
The Great Pretender
Re: vague steering
Post by The Great Pretender » Fri Feb 20, 2009 12:37 am
mister munkey wrote:Another obvious is tyre presures.
Wise words................ =D> =D> =D>
