fuel gauge
davylaa
fuel gauge
Post by davylaa » Fri Feb 06, 2009 11:08 am
Anyone had problems with their fuel gauge playing up? Sometimes the needle does'nt move at all and at other times when I know the tank is full or close to full it gives a much lower reading and starts to slowly decrease. Any advice would be appreciated.
moonshine
Re: fuel gauge
Post by moonshine » Fri Feb 06, 2009 11:15 am
Not had the problem myself, but others on here have had similar. The best place to start looking is the earth connection at the sender unit, or so I have read.
davylaa
Re: fuel gauge
Post by davylaa » Fri Feb 06, 2009 11:25 am
Thanks but where would i find the sender unit
Re: fuel gauge
Post by Doone » Fri Feb 06, 2009 11:29 am
Re: fuel gauge
Post by bigdaddycain » Fri Feb 06, 2009 2:50 pm
Thanks Doone, my gauge has started to play up, i'll have a dig around via your links... :P
Re: fuel gauge
Post by francophile1947 » Fri Feb 06, 2009 3:35 pm
bigdaddycain wrote:Thanks Doone, my gauge has started to play up, i'll have a dig around via your links... :P
Don't tell me you've got a dirty connection :shock: - must be the only thing you haven't polished :lol: :lol: :lol:
daveblueozzie
Re: fuel gauge
Post by daveblueozzie » Fri Feb 06, 2009 3:38 pm
if only you could see his bongo at this very minute, you would cry. talk about dirty :shock:
Lost without my Bongo.
Re: fuel gauge
Post by bigdaddycain » Fri Feb 06, 2009 3:42 pm
:cry: :cry: :cry:
loftustowncrier
Re: fuel gauge
Post by loftustowncrier » Fri Feb 06, 2009 5:59 pm
Mine seems to stick at 3/4 full when I fill it to the brim. It does go down, but slower than expected. I seem to have been on just over half a tank for ages though.... for all I know it could be running on fumes!
:shock:
Re: fuel gauge
Post by mikeonb4c » Fri Feb 06, 2009 6:22 pm
loftustowncrier wrote:Mine seems to stick at 3/4 full when I fill it to the brim. It does go down, but slower than expected. I seem to have been on just over half a tank for ages though.... for all I know it could be running on fumes!
:shock:
I'd say fuel sender again. Mind you, on another thread you've mentioned your RPM readout as being at variance with other peeps. Is it possible that the various instruments on the panel rely on a common earth which - in your Bongo - is behaving badly? :?
ex25er
Re: fuel gauge
Post by ex25er » Fri Feb 06, 2009 7:16 pm
Mine seems to move towards 'empty' alarmingly quickly for some reason..... :?
davylaa
Re: fuel gauge
Post by davylaa » Fri Feb 06, 2009 7:32 pm
Many thanks all. Will check out sender unit and earth at weekend. You are a helpful lot.
