banjo filter needed quick.....
scanner
Re: banjo filter needed quick.....
Post by scanner » Thu Jan 15, 2009 4:20 pm
francophile1947 wrote:
scanner wrote:Must be moisture getting in through the pipes. :wink:
Or the seals :wink: :lol: :lol:
Or the little hole in the filler cap.
Post by francophile1947 » Thu Jan 15, 2009 5:38 pm
scanner wrote: Or the little hole in the filler cap.
Is that the one with the extractor fan? :lol:
So, where does the stuff that blocks the banjo strainer come from? :?
scanner
Post by scanner » Thu Jan 15, 2009 6:01 pm
francophile1947 wrote: So, where does the stuff that blocks the banjo strainer come from? :?
Dunno :? but if it can block the strainer you don't want it going through the pump do you? [-X
Post by francophile1947 » Thu Jan 15, 2009 6:13 pm
scanner wrote:if it can block the strainer you don't want it going through the pump do you? [-X
Definitely not :roll:
dandywarhol
Post by dandywarhol » Thu Jan 15, 2009 7:05 pm
It's probably fibres from the fuel filter....................
bongomaan
Post by bongomaan » Thu Jan 15, 2009 7:10 pm
thats a thought it could be moisture coming in through the leaky pump seals,if i hear back from lawson diesel i"ll order some,been putting it off but its looking like a whole weekend on the bongo next weekend,(banjo/pump seals/glow plugs/and two sensors to check) will it ever end ??????......
Post by bigdaddycain » Fri Jan 16, 2009 1:33 pm
The "banjo" filter is the last line of defense before any contaminants enter the pump, anything trapped by the filter could eventually gum up the injectors.... :shock:
(why does the shocked emoticon now look like a constipated alien?) :shock: :shock: :shock:
Post by francophile1947 » Fri Jan 16, 2009 1:41 pm
bigdaddycain wrote:(why does the shocked emoticon now look like a constipated alien?) :shock: :shock: :shock:
Perhaps it IS a constipated alien, after it saw your orange wig 8) :lol: :lol: :lol:
Post by bigdaddycain » Fri Jan 16, 2009 1:46 pm
I'd have thought the image of me donning my carrot top would have made anybody 5h1t themselves...be they human or not john! :lol:
Hang on a mo... Nah, this one's gotta be the alien in need of relief: :x
Post by francophile1947 » Fri Jan 16, 2009 1:52 pm
Yep - I reckon it's how he/she (gotta be politically correct :lol: ) looked just before filling their pants :lol: :lol: :lol:
scanner
Post by scanner » Mon Jan 26, 2009 7:23 pm
The last of these assortments would be handy for any one intending to clean their Banjo filter to have around, in case one of the washers goes walkabout.
http://www.aldi.co.uk/uk/html/offers/58_8707.htm
dandywarhol
Post by dandywarhol » Mon Jan 26, 2009 7:26 pm
Never heard of "zinc-plated A3 hardened steel" fibre washers before..................... :roll:
scanner
Post by scanner » Mon Jan 26, 2009 7:42 pm
dandywarhol wrote:Never heard of "zinc-plated A3 hardened steel" fibre washers before..................... :roll:
AND
If they were A3 in size you'd have a job getting them into place.
I think that bit should have been inserted above the washers. :roll:
scanner
Post by scanner » Mon Jan 26, 2009 7:44 pm
I think the grommets should be below that as well - I don't fancy cables chafing on zinc plated steel grommets.
