rear washers problem
Re: rear washers problem
Post by bigdaddycain » Mon Jan 05, 2009 4:47 pm
kernowbongo wrote:problem solved. It turned out to be a broken pipe connector on the top of the tailgate. thanks to everyone who gave a sensible, helpful answer.
I've never looked... Is it a similar set-up as i envisage, with a ribbed plastic nozzle coming from the rear of the washer?
In which case, did you have to replace the whole washer nozzle assembly? :-k
splash2
Post by splash2 » Fri Jan 23, 2009 12:09 pm
I have a similar problem but, I can't find any leaks from the pipe-work. Does the front washer share the same motor/pump as the rear washer? I don't hear a pump running when I operate the rear washer from the steering column stalk. :( Rear wipers are fine so I know it's not a fuse. :? :?
Post by missfixit70 » Fri Jan 23, 2009 12:29 pm
aitch wrote:don't forget the rear pump is higher in the container than the front pump so the rear will allways stop working first.
:D
splash2
Post by splash2 » Fri Jan 23, 2009 12:39 pm
Thanks for that - I checked. I have solved the mystery - someone had disconnected the rear washer pump :? :? :? which has thrown up another problem that I probably shouldn't go in to right now.
Post by bigdaddycain » Fri Jan 23, 2009 1:40 pm
splash2 wrote: someone had disconnected the rear washer pump :? :? :? which has thrown up another problem that I probably shouldn't go in to right now.
Ok....NOW i'm intrigued! :shock:
splash2
Post by splash2 » Sat Jan 24, 2009 5:14 pm
Sorry to keep you in suspense. Having re-connected the rear washer motor I have a rather impressive flow of water.......down the inside of the windscreen on the passenger side. Now, I'm no Sherlock but, as a newly imported vehicle, one wonders how it passed an MOT in this condition. Hmm. Perhaps it didn't.
Post by francophile1947 » Sat Jan 24, 2009 5:21 pm
I don't think rear washers come under the MOT.
