rear washers problem
kernowbongo
Post by kernowbongo » Fri Jan 02, 2009 6:55 pm
Hi, our rear window washers have stopped working. When the washer button is pressed the washer motor pumps the fluid but it leaks out somewhere above the exhaust pipe. I presume the pipe is broken somewhere. Does anybody know if this is a common fault, and where the break is likely to be ?
Thanks for your help
Kernowbongo
Kernowbongo does it dreckly
trevd01
Re: rear washers problem
Post by trevd01 » Fri Jan 02, 2009 7:59 pm
Was the rear jet frozen?
mick
Post by mick » Fri Jan 02, 2009 9:47 pm
I think the pipe feeds across the roof of the Bongo, so the leak isn't coming from underneath. Mine came adrift on the top of the tailgate. I guess a leak from where mine broke could run down through the panels to drip underneath ?
aitch
Location: in a place far, far away, well Somerset for now!!!
Post by aitch » Fri Jan 02, 2009 11:47 pm
don't forget the rear pump is higher in the container than the front pump so the rear will allways stop working first.
Post by Bob » Sat Jan 03, 2009 12:44 am
Well spotted Aitch. :D
Post by missfixit70 » Sat Jan 03, 2009 12:51 am
kernowbongo wrote:Hi, our rear window washers have stopped working. When the washer button is pressed the washer motor pumps the fluid but it leaks out somewhere above the exhaust pipe. I presume the pipe is broken somewhere. Does anybody know if this is a common fault, and where the break is likely to be ?
Kernowbongo
Not that well spotted :wink:
Post by Bob » Sat Jan 03, 2009 1:14 am
Well it might be leaking from the high rear pump, onto the manifold. We need to look at all possibilities. :D
Post by missfixit70 » Sat Jan 03, 2009 2:07 am
Yeah, but, no, but, the exhaust manifold is a few feet behind the washer bottle & pump :wink:
kernowbongo
Post by kernowbongo » Sat Jan 03, 2009 4:31 pm
Hello again. perhaps i wasnt explicit enough about the location of the leak. The washer fluid is leaking from somewhere around the tailgate and dripping onto the rear exhaust silencer and tail pipe.
Post by mikeonb4c » Sat Jan 03, 2009 4:46 pm
kernowbongo wrote:Hello again. perhaps i wasnt explicit enough about the location of the leak. The washer fluid is leaking from somewhere around the tailgate and dripping onto the rear exhaust silencer and tail pipe.
I think Mick and Trevor are on the right lines. Sounds like the pipe has come off the nozzle connection, or summat like that :roll:
trevd01
Post by trevd01 » Sat Jan 03, 2009 6:23 pm
trevd01 wrote:Was the rear jet frozen?
I should be less cryptic. If the rear jet freezes, and you try and wash the rear screen, the pressure from the washer pump can push the washer fluid pipe off a dodgy joint, which could be in the rear door.
KennethB
Post by KennethB » Sat Jan 03, 2009 9:03 pm
I have the same problem at the moment. If the washer bottle is low will the rear jet stop working first?
Post by missfixit70 » Sat Jan 03, 2009 9:06 pm
Yep, as Aitch said earlier in the thread, it has a higher take off from the washer bottle, so will stop working before the front washers.
kernowbongo
Post by kernowbongo » Sun Jan 04, 2009 8:50 pm
problem solved. It turned out to be a broken pipe connector on the top of the tailgate. thanks to everyone who gave a sensible, helpful answer.
Post by mikeonb4c » Sun Jan 04, 2009 10:11 pm
kernowbongo wrote:problem solved. It turned out to be a broken pipe connector on the top of the tailgate. thanks to everyone who gave a sensible, helpful answer.
Hurrah and well done =D>
PS - any indication that the cold weather (e.g. fluid freezing in the pipe) might have triggered it? Or maybe its time was simply up!
