I've got two broken dashboard vents and I have got replacements from BongoBits. On a scale of 1 to 10 how complicated is it replace the vents.
Has anyone who has done the job got any words of advice.
Mark
Broken dashboard vents - advice
Beep Beep Beep Beep Beep Beep Beep.............. Ok I give up what have we left on!!!!!!!
- missfixit70
Re: Broken dashboard vents - advice
Don't do it
http://www.igmaynard.co.uk/bongo/forum/ ... hilit=vent , not a vast amount of help, but it is possible. Which ones need replacing? If it's the side ones I think they're a bit easier as the end panel on the dash comes out.
One is the drivers door side & the other is one of the central vents. Will investigate the side vent, would be happy with one out of two.missfixit70 wrote:Don't do ithttp://www.igmaynard.co.uk/bongo/forum/ ... hilit=vent , not a vast amount of help, but it is possible. Which ones need replacing? If it's the side ones I think they're a bit easier as the end panel on the dash comes out.
Thanks for your honest opinion.
Mark
