Inhibitor switch
WISHIHADABONGO
Inhibitor switch
Post by WISHIHADABONGO » Mon Nov 10, 2008 9:33 pm
Can anyone point me in the right direction, me Bongo will start one minuite and not the next and its not the starter. :oops:
Re: Inhibitor switch
Post by missfixit70 » Mon Nov 10, 2008 9:43 pm
Damp/knackered glow plug relay? what's it doing/not doing?
Post by francophile1947 » Mon Nov 10, 2008 9:44 pm
What inhibitor switch? :? :?
WISHIHADABONGO
Post by WISHIHADABONGO » Mon Nov 10, 2008 9:47 pm
Aint there a switch to stop you starting any auto vehicle unless its in neutral or park?
Post by Bob » Mon Nov 10, 2008 9:53 pm
WISHIHADABONGO wrote:Aint there a switch to stop you starting any auto vehicle unless its in neutral or park?
Yes, are you trying to start it in Drive? ('D', not the parking place in front of your garage.)
Post by francophile1947 » Mon Nov 10, 2008 9:59 pm
I wondered why that happened :oops: :oops: :oops: :lol: :lol: :lol:
dandywarhol
Post by dandywarhol » Mon Nov 10, 2008 11:01 pm
spout
Post by spout » Tue Nov 11, 2008 8:24 am
I had an embarrassing few minutes over the weekend when I also discovered that you can't change out of Park without your foot on the brake :oops:
Post by Bob » Tue Nov 11, 2008 9:51 am
Thanks for owning up, this could well help someone else. =D>
Trouble at t'Mill
Post by Trouble at t'Mill » Tue Nov 11, 2008 11:20 am
Hi WISHIHADABONGO.
Are you saying that when you turn your ignition key to 'crank' absolutely nothing happens?
Try gently rocking the gear lever back and forth in it's 'Park' position. Also, release and reapply the handbrake (not quite sure if this is connected), and pump your foot brake (ditto!).
And try again...
dandywarhol
Post by dandywarhol » Tue Nov 11, 2008 8:39 pm
Trouble at t'Mill wrote:Hi WISHIHADABONGO.
And try again...
WHY :|
Trouble at t'Mill
Post by Trouble at t'Mill » Wed Nov 12, 2008 10:52 pm
Hi dandywarhol, isn't the gearselector electrically connected as to isolate the starting of the engine unless it's in 'Park'?
I thought it was - apologies if I'm wrong - so I was 'speculating' that the same could also apply to the handbrake, etc.
The Freda I've just bought for my niece has done this a couple of times over the past week - key goes in, turns ignition on, but absolutely nothing when turned to 'crank'. A little 'rattle' of the gear selector and it fires up.
Probably coincidence :oops:
dandywarhol
Post by dandywarhol » Wed Nov 12, 2008 11:07 pm
You're right - the inhibitor switch only allows it to start in P or N - I just couldn't get the handbrake/footbrake dance...... :?
Trouble at t'Mill
Post by Trouble at t'Mill » Thu Nov 13, 2008 10:33 am
:D Ha ha - I see what you mean!
When this happened to me last week, my body just seemed to go into automatic convulsions - with all my limbs pumping on whatever they happened to be touching...
The Bongo then fired up instantly, so I wasn't able to eliminate which - if any - of the likely 'pumps' actually sorted the problem!
Since the footbrake then needs to be pressed before the gear selector can be shifted, I just thought the starting 'connection' might go further than just the gear selector itself - but obviously I don't know.
Does the handbrake switch have any bearing on the starting/gear selection process? Ie: can the car be started, or the gear selector moved with the handbrake in the 'off' position? (Saves me having to go out and check...)
Cheers.
WISHIHADABONGO
Post by WISHIHADABONGO » Sun Dec 07, 2008 6:31 pm
Some great advice here thanks!
