what type hydraulic lifters on v6 petrol,and how to remove?
hogggman
Post by hogggman » Sat Oct 11, 2008 10:24 pm
hi all,
tomorrow i am intending to remove the rocker covers on my tappetty v6,and hope to inspect the camshafts for wear........hopefully there won`t be any,or it`ll be minimal,and so then i`ll remove the camshafts and then the hydraulic lifters.can anyone advise me in advance of any problems i may encounter?what type are the lifters on the v6?the flat`dish`type,or the longer`bullet`type,and are there any tips for removal,dismantling or cleaning etc.
thanks
jamie
hogggman
Re: what type hydraulic lifters on v6 petrol,and how to remove?
Post by hogggman » Sun Oct 12, 2008 9:04 am
anyone...................?
Jolly Rogers
Post by Jolly Rogers » Sun Oct 12, 2008 9:10 am
Sorry can't help. I sure someone will be along soon with advice .
Post by francophile1947 » Sun Oct 12, 2008 10:47 am
Trouble is Jamie, there's still not that many V6s around that have had this type of work done on them.
hogggman
Post by hogggman » Sun Oct 12, 2008 11:05 am
hi,
i can be a gineau pig then!!i hope to remove the rocker covers and take it from there.i will take pictures at each stage,partly to help me when reassembling,and partly to post pics on here for advice as to whether anything`s worn etc.
at least that`s the plan.i don`t have a driveway and have to work in the street.some git parked outside my house and the bongo is down the street.i hate working on cars outside other people`s houses,so i`m waiting for someone to move their car.meanwhile,the missus wins as i`ll be tiling the kitchen!!not as interesting,but less espensive if something goes wrong!
i`ll let you know how it goes.(the bongo,not the tiling!)
thanks
jamie
manners
Post by manners » Sun Oct 12, 2008 3:05 pm
Hi Jamie they are the bullet type, some of the ones they took out of mine looked like they had been chewed! is it worth going to all that trouble without having some replacements if they are as bad as mine :?:
hogggman
Post by hogggman » Sun Oct 12, 2008 3:06 pm
hi manners,
did i read on another post that hillside did yours?
thanks
jamie
manners
Post by manners » Mon Oct 13, 2008 5:38 pm
Hi Jamie, yes Hillside did change them under warranty but the engine is still a bit noisy :( when i start it from cold you can hear the tappets go quite after a few seconds but when driving i can hear a tappet ticking sound but only when the accelerator is pressed (load on the engine) when its coasting or ticking over the noise goes so iam now thinking it could be the fuel injectors :?: Does yours stay noisy all the time :?:
cheffy34
Post by cheffy34 » Thu Oct 16, 2008 1:07 am
manners wrote:Hi Jamie, yes Hillside did change them under warranty but the engine is still a bit noisy :( when i start it from cold you can hear the tappets go quite after a few seconds but when driving i can hear a tappet ticking sound but only when the accelerator is pressed (load on the engine) when its coasting or ticking over the noise goes so iam now thinking it could be the fuel injectors :?: Does yours stay noisy all the time :?:
I hear that tappeting noise when driving only, i've nailed it to the electric solanoid on the return valve to the carbon canistor(evap valve) goes away when coasting :wink: mines been like it since i got it, another v6 on tthe forum has suffered the same but not heard from him in a while :cry: £70 from mazda i'm still trying to find a cheaper one :wink:
cheffy34
Post by cheffy34 » Thu Oct 16, 2008 1:11 am
Ps manners
it not so noisy if you have the passenger window closed :D :wink:
manners
Post by manners » Thu Oct 16, 2008 7:36 am
Thanks for that, where is it and what does it look like :?:
cheers manners.
cheffy34
Post by cheffy34 » Thu Oct 16, 2008 8:44 am
manners wrote:Thanks for that, where is it and what does it look like :?:
cheers manners.
Its under your passenger seat beside a big black canistar on the chasis , its all part of the EGR begs the question if it can be disconnected like our brother diesals, not sure on that one tho prob end up stinking of petrol like the olden day motors did, maybe one of our mechanical friends can enlighten us :wink: There are pictures of it on one of my previous posts to hog do a search for it
Dar :wink:
apole
Post by apole » Thu Oct 16, 2008 9:21 am
Hi guys,
Regarding the EGR disconnection, I researched that alot and didn't find anything useful. I did try and unplug the wire that goes to the EGR, didn't make any difference that I could tell other than throw up an error code in the ECU.
Hoggman, for the parts give these guys a call:
Holdcroft Mazda for paint etc Ashley Smith on 01782 202330
Regards
Andy
dandywarhol
Post by dandywarhol » Thu Oct 16, 2008 11:40 am
Any fuel fumes, tank injection system etc. must (legally) vent to the charcoal filter canister and then its recycled into the system.
Why not wrap the soleniod in foam???
cheffy34
Post by cheffy34 » Fri Oct 17, 2008 8:56 am
dandywarhol wrote:Any fuel fumes, tank injection system etc. must (legally) vent to the charcoal filter canister and then its recycled into the system.
Thank you wise one :D thought that would be the case, your the second person to say wrap the solenoid in foam, old mechanics trick i assume dandy :?: i've kinda learnt to ignore it crank up radio sit me son in passenger seat etc, they all do it dont they dandy just more noticable on bongo cause your sat on it :?:
Darren
