heatherpetch
Post
by heatherpetch » Wed Oct 08, 2008 7:43 pm
Hi guys,can you confirm that the expansion tank top when you press the release button that it should pop back up on it's own
i am not sure if we have a problem or not
we keep losing a small amount of water no overheating probs,but when we topped up the tank today Garry noticed that the black button on the cap was pressed in,so should it be in or out
we think in so i hope you techie peeps out there can clear up the confusion please
cheers Heather
trevd01
Post
by trevd01 » Wed Oct 08, 2008 7:57 pm
Ours doesn't have a black button...
daveblueozzie
Post
by daveblueozzie » Wed Oct 08, 2008 7:59 pm
no black button on mine , just the same as Trev's
Lost without my Bongo.
heatherpetch
Post
by heatherpetch » Wed Oct 08, 2008 8:13 pm
ok then here is what we think if we press the black button it releases the pressure then if its sticking down the system is not pressurised
so this might be the cause of the water dissapearing instead of the pressure building as it should i think
its allowing water to escape,this only happens when the bongo has worked hard up hill etc,normal flat driving no loss
there is defo no overheating going on all hoses are ok,cheers confused.com
Post
by francophile1947 » Wed Oct 08, 2008 8:18 pm
I'd get a proper cap Heather - the one you've got doesn't sound standard at all - mine's the same as the others here.
daveblueozzie
Post
by daveblueozzie » Wed Oct 08, 2008 8:18 pm
i think you have the wrong pressure cap on the tank, it should look like the one in Trev's photo, YELLOW ON THE TANK AND RED ON THE RADIATOR.
heatherpetch
Post
by heatherpetch » Wed Oct 08, 2008 8:25 pm
daveblueozzie
Post
by daveblueozzie » Wed Oct 08, 2008 8:29 pm
you should not be losing water from the cap, it sounds like you just press it to release the pressure before you take the cap off. you may have a small leak elsewhere.
Post
by francophile1947 » Wed Oct 08, 2008 8:33 pm
daveblueozzie wrote:you should not be losing water from the cap,
Might lose some if this button isn't sealing properly Dave.
I'd have thought that a cap should be available at your local car spare shop - surely they're not specific to a Bongo
daveblueozzie
Post
by daveblueozzie » Wed Oct 08, 2008 8:37 pm
francophile1947 wrote:daveblueozzie wrote:you should not be losing water from the cap,
you are right John if its not sealing properly, but it does not sound like any cap ive seen, and ive helped fit a lot of coolant alarms and never seen one like heather's description
trevd01
Post
by trevd01 » Wed Oct 08, 2008 8:39 pm
This is the one on the rad...
Post
by francophile1947 » Wed Oct 08, 2008 8:44 pm
daveblueozzie wrote:francophile1947 wrote:daveblueozzie wrote:you should not be losing water from the cap,
Right Dave - I've never seen or heard of one either
It sounds dangerous if you should accidentally push the button when system is still hot and pressurised
daveblueozzie
Post
by daveblueozzie » Wed Oct 08, 2008 8:49 pm
Heather i would put a wanted post on the, er ,er
stuff wanted section
, for an expansion tank cap. you may be lucky someone may have a spare . then you will know if its that whats been leaking , with any luck thats all it is.
dandywarhol
Post
by dandywarhol » Wed Oct 08, 2008 9:04 pm
You'll get a 1.1 bar cap in most motor factors for around a fiver. They fit most Jap cars/vans
haydn callow
Post
by haydn callow » Wed Oct 08, 2008 10:05 pm
pm me your address and I'll pop one in the post...Quick though as I'm off on holiday Sat.
