expansion cap
heatherpetch
expansion cap
Hi guys,can you confirm that the expansion tank top when you press the release button that it should pop back up on it's own
i am not sure if we have a problem or not
we keep losing a small amount of water no overheating probs,but when we topped up the tank today Garry noticed that the black button on the cap was pressed in,so should it be in or out
we think in so i hope you techie peeps out there can clear up the confusion please
cheers Heather
trevd01
Re: expansion cap
Ours doesn't have a black button...
- daveblueozzie
heatherpetch
Re: expansion cap
Re: expansion cap
I'd get a proper cap Heather - the one you've got doesn't sound standard at all - mine's the same as the others here.
- daveblueozzie
Re: expansion cap
i think you have the wrong pressure cap on the tank, it should look like the one in Trev's photo, YELLOW ON THE TANK AND RED ON THE RADIATOR.
Lost without my Bongo.
heatherpetch
Re: expansion cap
well it is yellow but with this black button which says press to release
it also says 1.1 on it.Where would i get one from?and could it let water escape if it stays pressed in as this does release the pressure
- daveblueozzie
Re: expansion cap
you should not be losing water from the cap, it sounds like you just press it to release the pressure before you take the cap off. you may have a small leak elsewhere.heatherpetch wrote:well it is yellow but with this black button which says press to releaseit also says 1.1 on it.Where would i get one from?and could it let water escape if it stays pressed in as this does release the pressure
Re: expansion cap
Might lose some if this button isn't sealing properly Dave.daveblueozzie wrote:you should not be losing water from the cap,
I'd have thought that a cap should be available at your local car spare shop - surely they're not specific to a Bongo
- daveblueozzie
Re: expansion cap
you are right John if its not sealing properly, but it does not sound like any cap ive seen, and ive helped fit a lot of coolant alarms and never seen one like heather's descriptionfrancophile1947 wrote:Might lose some if this button isn't sealing properly Dave.daveblueozzie wrote:you should not be losing water from the cap,
I'd have thought that a cap should be available at your local car spare shop - surely they're not specific to a Bongo![]()
trevd01
Re: expansion cap
This is the one on the rad...
Re: expansion cap
Right Dave - I've never seen or heard of one eitherdaveblueozzie wrote:you are right John if its not sealing properly, but it does not sound like any cap ive seen, and ive helped fit a lot of coolant alarms and never seen one like heather's descriptionfrancophile1947 wrote:Might lose some if this button isn't sealing properly Dave.daveblueozzie wrote:you should not be losing water from the cap,
- daveblueozzie
Re: expansion cap
Heather i would put a wanted post on the, er ,er
stuff wanted section
, for an expansion tank cap. you may be lucky someone may have a spare . then you will know if its that whats been leaking , with any luck thats all it is.
- dandywarhol
Re: expansion cap
You'll get a 1.1 bar cap in most motor factors for around a fiver. They fit most Jap cars/vans
- haydn callow
Re: expansion cap
pm me your address and I'll pop one in the post...Quick though as I'm off on holiday Sat.
