Oil leak from head.
brorabongo
Oil leak from head.
Post by brorabongo » Mon Sep 22, 2008 11:27 pm
Just below the wee red arrow, is where I'm leaking engine oil. Not a lot but I have had to top up the level. :? The leak is between the head and the block right below a head bolt. I am hoping tightening the bolt might solve it, but the bolts not an easy one to get to.
I've stuck in some of this stuff....Millers Do you think it will do the job???
OR any other ideas please. [-o<
Cheers.
ボンゴの激怒 pictures
Simon Jones
Re: Oil leak from head.
Post by Simon Jones » Tue Sep 23, 2008 12:01 am
My engine used to have oil around that spot on the head gasket. Whether it came from the gasket itself, or just accumulated there from the EGR, I was unable to tell. When I replaced the head gasket, I thoroughly cleaned the oil from the sides of the block & then used Wellseal around the gasket. Since then, I've had no water or oil leaks.
I don't believe tightening the head bolts is the solution. They are stretch bolts that are designed to work under tension. It is not recommended that they be re-used as they can loose their elastic properties, so re-tighening would tend to come under the same heading. Have a look at http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=25383 - unless it is causing real concern, it is probably best left alone, but keep an eye on it to see if it deteriorates.
helen&tony
Post by helen&tony » Tue Sep 23, 2008 9:05 am
I'm in agreement with Simon, there, but if you wish to check, then an oil pressure gauge may assist you in comparing your oil pressure to factory spec. The one problem you may have, is that if there is a worsening leak, then by not repairing it , you may get head warping, and further problems.....Degrease it with Jizer / Gunk, and keep an eye on it....Good Luck
brorabongo
Post by brorabongo » Tue Sep 23, 2008 9:56 am
Cheers folk. :D
The photo was taken pre-cleaning. I then run the engine, and noticed it was that place where the oil is coming from. I have read the other post and have a post or two on it. That problem is more to do with Rocker > Head, and not as in my case Head > Block.
You can see the oil seeping out whilst the engine is running. 8-[
ボンゴの激怒 pictures
Simon Jones
Post by Simon Jones » Tue Sep 23, 2008 11:29 am
brorabongo wrote: You can see the oil seeping out whilst the engine is running. 8-[
Mmm - that does sound a little more serious than other vans have experienced. I suppose that leaves 3 options:
1) Leave it as it is.
2) Put some sealant around the leak. Due to way the head & block are 'stepped', this may be quite tricky.
3) Take the head off, change the gasket & use suitable sealer like Wellseal to ensure it doesn't happen again.
It may be due to excess oil pressure, so it may be worth getting it tested as Helen & Tony has suggested. Does anyone know what the correct pressure should be?
Post by bigdaddycain » Tue Sep 23, 2008 11:35 am
Has the head been replaced at some stage in a past life? Was the head and block skimmed prior to fitting? It's expecting a lot of the gasket to seal properly if the mating faces aren't true in the first place.
haydn callow
Post by haydn callow » Tue Sep 23, 2008 1:20 pm
looks like EGR crud to me....do you have to top up the oil between changes??
http://www.coolantalarm.co.uk
Also BMW Clocks
brorabongo
Post by brorabongo » Tue Sep 23, 2008 1:57 pm
haydn callow wrote:loolike EGR crud to me....do you have to top up the oil between changes??
I have had to top up, and I'm due a change.
bigdaddycain wrote:Has the head been replaced at some stage in a past life? Was the head and block skimmed prior to fitting? It's expecting a lot of the gasket to seal properly if the mating faces aren't true in the first place.
Not to my knowledge, having said that I've only had her 19months. It only started to lose a little oil recently.
Simon Jones wrote:Mmm - that does sound a little more serious than other vans have experienced. I suppose that leaves 3 options:
1) & 2) are ones I can do. :lol: 3) is too big a job for me!! 8-[
I'm trying oil stop leak at the mo, and then I'll change the oil and see. Failing that it's to a garage she goes..... :(
Cheers. :D
ボンゴの激怒 pictures
haydn callow
Post by haydn callow » Tue Sep 23, 2008 2:16 pm
Just reread the post and note you are having to top up.
Also BMW Clocks
brorabongo
Post by brorabongo » Thu Oct 30, 2008 10:25 am
Wynn's "Oil Stop leak" stuff seems to have worked. \:D/
Changed oil after doing a few hundred miles with the stuff in, and no sign of any loss for what must be around a thousand miles now. :D
ボンゴの激怒 pictures
Post by mikeonb4c » Thu Oct 30, 2008 3:14 pm
brorabongo wrote:Wynn's "Oil Stop leak" stuff seems to have worked. \:D/
Amazing - wonder how it works and if they do a 'Wynns Diesel Injector Fuel Stop Leak' :lol: :lol: :lol:
lizard
Post by lizard » Thu Oct 30, 2008 6:38 pm
Great news
Wonder if they do a Wynns Hair Loss Stop
:lol:
F Zappa
Post by mikeonb4c » Thu Oct 30, 2008 7:00 pm
Made me laugh that did Lizard :lol: :lol: :lol:
My wife is hoping for a can of 'Wynns Wipe Out Your Husband' :lol: :lol: :lol:
