Testers WANTED
haydn callow
Testers WANTED
Post by haydn callow » Tue Aug 05, 2008 4:03 pm
Anybody interested in fitting and testing/reporting on this below?
You MUST have a Coolant Loss Alarm Fitted.
I have made 4 prototypes.
I have one fitted.
Rooster is getting one.
That leaves the first 2 to contact me.
Takes about 15 mins to fit and is so easy it isn't true (yes it is)
10mm spanner and a philips screwdriver.
It would be good if one of the testers tends to give the Bongo a bit of a thrash now and again and if poss have a TM2 fitted.
""HAYDN”
Low Coolant Alarm
ADD ON KIT
By putting this kit into your low coolant alarm circuit you will have a “extra” bit of protection against overheating.
If !! when this is fitted your alarm sounds.. you will have either lost coolant or exceeded 110oC at the cylinder head.
If this happens you must stop AT ONCE and investigate the cause.
TO FIT
Simply fit the thermal switch under a rocker cover bolt ( I have used the 2nd from the front under the passenger seat)
Connect the female spade connectors to the thermal switch.
Run the wires carefully to your coolant alarm module (away from the engine and protecting them against “trapping”)
Unplug the bullet connector (in the sensor wire) at the module and plug in the thermal switch wires (one male & one female)
NOTE:- the switch resets when the temp drops to 90oC
JOB DONE
http://www.coolantalarm.co.uk
Also BMW Clocks
helen&tony
Re: Testers WANTED
Post by helen&tony » Tue Aug 05, 2008 4:12 pm
Hi Haydn
I've PM'd you
Re: Testers WANTED
Post by francophile1947 » Tue Aug 05, 2008 4:14 pm
You have a PM.
haydn callow
Re: Testers WANTED
Post by haydn callow » Tue Aug 05, 2008 4:26 pm
O.K. folks
Thats the 2 x testers sorted.
I can if someone is really keen knock up one more. (must have coolant alarm and tm2 fitted)
Haydn
Also BMW Clocks
Majorbloodnock
Re: Testers WANTED
Post by Majorbloodnock » Tue Aug 05, 2008 4:35 pm
Sounds great! In true MajorBN tradition I am dragging my heels with all this coolant alarm stuff, so...should I be waiting longer to buy and fit my alarm as they will come standard with the "extra add-on bit" in future? [-o<
haydn callow
Re: Testers WANTED
Post by haydn callow » Tue Aug 05, 2008 4:41 pm
NO !! don't wait you may need the coolant loss bit tomorrow. This "add on" if it goes into production will be available to all at a very resonable price. I would guess around £15. It will be the same if included in a kit.
DON'T Delay.
Also BMW Clocks
scanner
Re: Testers WANTED
Post by scanner » Tue Aug 05, 2008 5:02 pm
I'm doing a trip to Germany and back next week so I can test one on a journey with plenty of motorway cruising and a few hills if you like.
Not sure if I have a TM2 though - just the coolant alarm I bought at Stourport?????
haydn callow
Re: Testers WANTED
Post by haydn callow » Tue Aug 05, 2008 5:16 pm
Scanner...I would really like someone with a TM2 fitted so they would be able to tell at what Temp the switch "alarms" at. Supposed to be 110oC +/- 3 degrees.
Thanks anyway. Will be in touch if any more developement is needed.
Also BMW Clocks
scanner
Re: Testers WANTED
Post by scanner » Tue Aug 05, 2008 6:10 pm
haydn callow wrote:Scanner...I would really like someone with a TM2 fitted so they would be able to tell at what Temp the switch "alarms" at. Supposed to be 110oC +/- 3 degrees.
Ahh wasn't sure whether I had a TM2 or not - obviously not. Just the low coolant one and a Mason. Presumably if I had a TM2, I wouldn't really need the Mason one.
