Charge and sediment lights on: Polish emergency!
Post by Ian » Thu Jul 31, 2008 4:19 pm
Text received from Polish contingent. One vehicle has charge and sediment lights on permanantly. Alternator holding charge OK. Banjo filter , fuel filter and water trap all OK. Said I would get back to them....forum search reveals that this is a classic case of alternator on its way out.
The key decision is should they continue? They are 3 hours from destination. My guess is that they should keep moving, and then source a new alternator once at campsite' if vehicle makes it.
I am just off to airport hotel (in 10 mins!) so will check on forum for responses tonight.
scanner
Re: Charge and sediment lights on: Polish emergency!
Post by scanner » Thu Jul 31, 2008 4:25 pm
They should be able to make it if they use as little power as possible should the alternator actually give up completely.
Better to at the campsite waiting for an alternator than stuck at the side of the road.
Can't you take one out in your hand baggage?
mister munkey
Post by mister munkey » Thu Jul 31, 2008 4:44 pm
If any others have a twin battery pack, have one on standby to use if they don't get the full 3 hours out of the duffer. When mine went, I got little more than an hour of running with everything off, even using the handbrake & gears to slow down to save a bit of juice.
Fingers crossed!!
[-o<
scanner
Post by scanner » Thu Jul 31, 2008 5:08 pm
mister munkey wrote:If any others have a twin battery pack, have one on standby to use if they don't get the full 3 hours out of the duffer. When mine went, I got little more than an hour of running with everything off, even using the handbrake & gears to slow down to save a bit of juice.
Fingers crossed!!
[-o<
If it's a diesel all it needs is enough voltage to keep the fuel cut off solenoid open.
If nothing else is switched on there should be little or no drain on the battery as there is no ignition system to power.
A decent battery should last far more than 3 hours, yours must have been well discharged to last only an hour.
Dago & Mrs D
Post by Dago & Mrs D » Thu Jul 31, 2008 5:37 pm
Can anyone in the North West Section get an alternator to the Holiday Inn at Speke tonight!
It needs to be 'boxed' so that it can be taken on the plane.
This is for Ian Maynard to take out to Poland with him. See Techie section " Charge & Sediment Lights on" Topic. He will be arriving at the Holiday Inn from 1930 hrs tonight
I am acting as a relay for Ian's request. If you can help at all.
It is an EMERGENCY.
Fingers Crossed & thanks in anticipation
Dago
B*Witched Blingo
Post by B*Witched Blingo » Thu Jul 31, 2008 6:32 pm
Could Ian not call Wheelquick to see if he has one in stock? Just a thought.
You Tube Films Click Here
Dago & Mrs D
Post by Dago & Mrs D » Thu Jul 31, 2008 6:46 pm
He's en route to the airport, he was hoping that someone 'local' could do that.
How far away are Wheelquick?
B*Witched Blingo
Post by B*Witched Blingo » Thu Jul 31, 2008 7:08 pm
Just texted Ian..to offer help... He has replied, DBO is on with it as we speak....Phew...
daveblueozzie
Post by daveblueozzie » Thu Jul 31, 2008 7:14 pm
ALL SORTED . picking alternator and belts up at Mike (wheelquick) house later. =D> then off to Speke (holiday inn) with the good guidance of DABS and his sat nav. =D> accompanied by rooster.
Lost without my Bongo.
B*Witched Blingo
Post by B*Witched Blingo » Thu Jul 31, 2008 7:18 pm
Keep up the good work guys....
Tell Ian to have fun from us and hope the patient is running again very soon...
Dago & Mrs D
Post by Dago & Mrs D » Thu Jul 31, 2008 7:26 pm
Which just goes to prove - in an emergency all you need is a Bongonaut. :D Well done, many thanks, and a pat on the back to you all - especially Daveblueozzie =D>
Post by mikeonb4c » Thu Jul 31, 2008 9:08 pm
Unbe-effing-lievable. Our network makes DHL look amateur. Stunning work by Mr&Mrs D, DaveBlueOzzie, Wheelquick. =D> =D> =D>
Boy, at this rate, I can't wait to break down. It'll be the most dramatic Bongo Adventure yet :lol: :lol: :lol:
mister munkey
Post by mister munkey » Thu Jul 31, 2008 9:10 pm
BRILLIANT!!
=D> =D> =D> =D> =D> =D> =D> =D> =D>
Post by missfixit70 » Thu Jul 31, 2008 9:12 pm
I reckon that merits a lifetime membership for the Don, Dabs & the Dagos :wink:
BONGO-LOUIS
Post by BONGO-LOUIS » Thu Jul 31, 2008 9:27 pm
:roll: cor blimey you lot this is better than batman & robin well done i feel so safe bein involved with you guys.... =D> =D> =D>
DBO & his Bongo Mobil :lol: :lol:
Tina Bongo-louis
