TM2 numbers
Lewy
TM2 numbers
Post by Lewy » Mon Jul 21, 2008 5:57 pm
After swapping the sensor on my TM2 to the INLET side and securing it underneath a middle rocker bolt and spacer so that it is directly on the head, I'm getting a much more consistent reading.
Paranoia aside the figures it is recording seem quite high though around 88-95 - usually around the 90/92 mark on hot days going up and down some quite steep hills on A roads and B roads of South Devon. I have a Mason alarm fitted too and can see the needle on the temp responding to hard hauls up hills.
I can see the temp numbers going up on hard hauls too and then dropping again when cruising or going downhill.
I know there are a lot of variables to consider in different vans but was wondering what temp people would expect a big diesel to generally work at?
haydn callow
Re: TM2 numbers
Post by haydn callow » Mon Jul 21, 2008 7:10 pm
Thats where mine is and readings are the same.
http://www.coolantalarm.co.uk
Also BMW Clocks
Lewy
Re: TM2 numbers
Post by Lewy » Mon Jul 21, 2008 7:23 pm
Thanks Haydn
