Split charge relay
Split charge relay
I wonder if anyone can give me some advice. I had booked my dual battery Bongo in to have a split charge relay fitted with a local auto electrical firm. However they are saying that there usual supplier is to struggling to source one. Willington doesn't seem to have any kits available on e-bay right now so I was wondering if anyone knows of a decent alternative supplier.
I am travelling from Hull to Zeebrugger on Sun for 3 weeks camping, so I'm getting a bit desperate!
Andrew
Andrew
				thedogsbollox
 - Tribal Elder
Re: Split charge relay
If you are desperate you can obtain the relay on its own easily enough
http://www.instructables.com/id/Fitting ... zda-Bongo/
http://cgi.ebay.co.uk/Smart-12s-Switchi ... dZViewItem
You can get a complete description of what is needed and how to fit it all here
If you are getting an autospark to do it then he will have no probs understanding it.
The BEP marine VSR is quite good value.
You can see one here http://www.power-store.com/?id=196
but buy somewhere cheaper, like here http://www.marinemegastore.com/product. ... =0&cat_id=
I tried looking on the BEP website but it's not respondning and Google has listed as a security risk so take care if you try to view it
I know a really good mobile auto electrician in Warrington.  Give me a shout if you'd like his details as knowing him he's probably got all you need in the back of his van
Steve
									Steve
Tin top Bongo camper, Peugeot Partner Combi, Kawasaki ZRX1100, Yamaha SR250SE
Just sent you a pm, I think you'r already using the guy I was recommending.
Any way, just found this on e bay that will be just the job:
http://cgi.ebay.co.uk/30A-SPLIT-CHARGE- ... 286.c0.m14
Thanks Steve
Ill order it this evening!
Cheers Andrew
Cheers Andrew
- missfixit70
Or email willinton via ebay, he may not have got around to listing, it's what I did.
I'm Just wondering if the 30amp relay on e-bay will be adequate Willingtons say they are 100amp. Any thoughts ?
I fitted the 100A relay with 50A fuses and made up leads from parts - it's a hassle but it worked for me.
From what I can see this is the right one:
http://www.rawcomponents.co.uk/100-amp- ... -144-p.asp
the company supply the parts as well I think.
Cloughy
Cloughy
				moonshine
60amp is the absolute minimum I would ever consider using.  100amp is best I think.  30amp is likely to melt if your battery is low, and your alternator starts pushing out 45amps or more.
http://www.rawcomponents.co.uk/100-amp- ... -144-p.asp , as cloughy says.
I've recently bought one of those for my boat.
Colin.
Colin.
Correct me if I'm wrong but the Nagares relay isn't voltage sensing.
As missfixit says, try emailing willinton via ebay.
If you can 't get one of those go and want to get the job done with minimum fuss in time for your hols get a BEP.
If the BEP is too expensive buy a TEM3m and use it to energise the Nagares (or similar high current relay) like the one Cloughy and Moonshine are refering to. Details can be found here http://www.igmaynard.co.uk/bongo/forum/ ... r&start=15 (Page 2, 6th post from the bottom). By the time your sparky has added the extra wiring / parts etc I'm sure the BEP woould have paid for itself!
I think willinton modifies the Nagares relay to make it voltage sensing. He had 2 on ebay earlier this evening: I bought one & the other one seemed to vanish too. definitely worth dropping him a message if you are still interested.
Your right Simon, Willinton does modify the Nagares.  If you buy one from anywhere else it won't do any voltage sensing.
I ordered the Willington in the end, not cheap but hopefully worth it.
Thanks for all the advice folks.
